Electronic Suggestion? April 19, 2016 04:13AM |
Re: Electronic Suggestion? April 19, 2016 04:00PM |
Re: Electronic Suggestion? April 19, 2016 05:52PM |
Re: Electronic Suggestion? April 20, 2016 03:47AM |
Re: Electronic Suggestion? April 20, 2016 01:00PM |
sarf2k4
As for the 32bit based arduino. I still never touched them and I'm not sure what is the most suitable firmware for them that is almost like marlin (I grow fond of marlin already)
Re: Electronic Suggestion? April 20, 2016 02:35PM |
Smoothieboards allow separate power for different things so if that board is used this is not true. I ran a 24v stepper/hot end system with 12v fans for example. You could split the hot end from the steppers as well.Quote
dc42
3. No, you need 24V bed heater and hot end heater, and probably 24V fans as well depending on the controller.
Re: Electronic Suggestion? April 20, 2016 02:46PM |
Koko76
dc42
Re: Electronic Suggestion? April 20, 2016 06:15PM |
Koko76
Smoothieboards allow separate power for different things so if that board is used this is not true.Quote
dc42
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Electronic Suggestion? April 20, 2016 06:33PM |
I am specifically referring to the physical hardware present on the board to allow independent power supplies to be connected. I personally don't like relying on PWM for things like that.Quote
Traumflug
Koko76
dc42
All boards allow this, it's a pure firmware thing. PWM is simply limited to less than 100% (typically to 70/255 = ~ 30%). I'd be suprised if Marlin doesn't support this.
Re: Electronic Suggestion? April 21, 2016 06:15AM |
Koko76
Re: Electronic Suggestion? April 21, 2016 09:00AM |
Then I suggest you take another look at how the fets are configured. I can tell you from the piece of hardware that I bought that it has independent power inputs and I used it in that fashion until I switched to a duet 0.85. I don't want a "Gen7", and truth be told I'm not wild about the smoothie either. But give it a rest guy, you are going to great lengths to try and disprove what exactly? It isn't anything against the solution that you developed that a different board exists.Quote
Traumflug
Koko76
Looking at [smoothieware.org] I see that Smoothiebard has only one power connector (and another one for 5V logic). The page explicitely talks about "reduced PWM settings" for connecting heaters when supplied with 24 V.
If you want independent inputs, get a Gen7. There you have distinct power connectors for steppers and heaters. No problem to run heaters at 12 V and steppers at 24 V at the same time.
Re: Electronic Suggestion? April 21, 2016 09:34AM |
Re: Electronic Suggestion? April 22, 2016 03:35AM |
Re: Electronic Suggestion? April 22, 2016 07:21AM |
Koko76
Re: Electronic Suggestion? April 22, 2016 10:45AM |
Then your reading comprehension is poor. What I described is documented. There's even a picture. But there's words too, so it might be tough. ill see if I have some time later to find and copy paste the exact section for you since this seems so difficult.Quote
Traumflug
Koko76
Why should I investigate the layout of this board? If the makers of it don't understand it and write wrong documentation, how could I be better?
That said, it's your statement that documentation is wrong. Me only cites what's written there.
Re: Electronic Suggestion? April 22, 2016 12:11PM |
Re: Electronic Suggestion? April 22, 2016 03:05PM |
Koko76
why are you so focused on kicking sand on it?
Re: Electronic Suggestion? April 22, 2016 03:16PM |
Koko76
... as well as being able to easily assign an M code of my choosing to turn one of available FET on or off (or PWM) is a great feature of this one. It's the feature I miss most in the Duet, which is also a good board.
Re: Electronic Suggestion? April 24, 2016 02:38AM |
Re: Electronic Suggestion? April 24, 2016 09:17AM |
sarf2k4
I am quite confused as to go for either smoothieboard or duet though, I read a little bit of smoothieboard instruction that it needs another 5v for logic, and that would need another 5v power supply or voltage regulator for that one.
I also forgot to state that I'm going to build a cartesian style 3d printer
Re: Electronic Suggestion? April 25, 2016 12:42PM |
So basically for smoothieboard it's a mandatory to have another 5v input? As for duet, just 12-24v would be sufficient as well right?Quote
ElmoC
sarf2k4
The Smoothieboard, like the Duet, has an option to supply 5v from a secondary supply. With the Smoothieboard, you need to add a 5V regulator to use a single supply. The Duet includes the components onboard for generating the 5V.
I have used both boards and personally, I prefer the Duet over the Smoothie.
Re: Electronic Suggestion? April 25, 2016 01:03PM |
sarf2k4
What of the duet firmware? will it support cartesian style?
Re: Electronic Suggestion? April 28, 2016 11:45AM |
Re: Electronic Suggestion? May 25, 2016 08:25AM |
sarf2k4
ElmoC
sarf2k4
Re: Electronic Suggestion? May 25, 2016 08:28AM |
Re: Electronic Suggestion? July 25, 2016 05:30AM |
Re: Electronic Suggestion? July 29, 2016 07:06AM |
Re: Electronic Suggestion? July 29, 2016 03:29PM |
Re: Electronic Suggestion? July 29, 2016 04:17PM |
the_digital_dentist
I recently upgraded the extruder and hot-end on a Solidoodle printer that has a printrboard controller. I had to flash the firmware to reset the maximum temperature limits so the machine could take full advantage of the new hot end. That's when the trouble started. First I had to get an obsolete version of the Arduino IDE - easy enough right now because Arduino keeps them on the web site - but then I had to go to the wayback machine to find an obsolete version of the teensy add-ons, and then hunt down the HID boot loader client, install all this stuff, then find a copy of Marlin with the Solidoodle specific changes and make my own changes after hunting through the config files for the appropriate variables.
Re: Electronic Suggestion? July 29, 2016 07:27PM |
