Anyone with a LJ18A3-8-Z/BX using Ramps 1.4 board? April 19, 2016 09:44AM |
Re: Anyone with a LJ18A3-8-Z/BX using Ramps 1.4 board? April 19, 2016 09:15PM |
Re: Anyone with a LJ18A3-8-Z/BX using Ramps 1.4 board? April 20, 2016 02:19AM |
Re: Anyone with a LJ18A3-8-Z/BX using Ramps 1.4 board? April 20, 2016 07:02AM |
DjDemonD
I have pretty much given up trying to understand these sensors. But there are ways to get them working. In the first example you might need to change your firmware settings. Assuming you're using marlin these are:
Z_min_endstop logic from true to false (or vice versa) and enable internal pull up resistors for Z_min_endstop.
There are obviously 4 combinations of settings, try them all and see if any combo gives you triggered when triggered and open when open.
As for the second problem I am told it's because there is no load on the sensor. So connect a small light bulb to the signal lead (or high OHM resistor/which is the equivalent of the internal pull up above) and measure again. They give spurious signals without a load.
Re: Anyone with a LJ18A3-8-Z/BX using Ramps 1.4 board? April 20, 2016 10:01AM |
Re: Anyone with a LJ18A3-8-Z/BX using Ramps 1.4 board? April 20, 2016 12:38PM |
ggherbaz
Did you wired right?
[www.google.com]
If you wired wrong, the sensor might be damaged.
Use a 12 volts power supply and the connect a 5 volts regulator to the (black) signal output.
