start printing in the x=0 y=-20 z=0 position
Posted by cearza
April 21, 2016 03:19AM
When I start printing I would like to move the extruder in the "Y" position about 20mm from the center of the heated bed to the front, how can I do this? I'm using repetier as my host. Thanks
Re: start printing in the x=0 y=-20 z=0 position
April 21, 2016 10:26PM
It will be up to you to not use this approach on a print that goes within 20mm of the edge of the bed, but G92 with a Y parameter will set the y position at that time to whatever value you set. You can use that to force an offset just after your home in your start gcode.
April 22, 2016 12:09AM
Awesome! thanks
April 22, 2016 12:27AM
You can adjust x and y in Slic3r, Printer Settings, Extruder 1.
