Hello guys,
I have a bit of a challenge for you. I have purchased a diamond hot end, and I want to run it next to my original hotend so I can print colors with the diamond, and supports or ninjaflex with the original. I am running Repetier firmware.
I saw that there is a procedure in the reprap wiki for mixing nozzles in Repetier Host, but it doesn't look like I can specify a separate nozzle just for supports. Is there a way to do this? I know I can set the offsets and everything, but the tricky part is telling it which extruders share a hot end and which don't.
Thanks in advance!
