Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 09:08AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 09:11AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 09:21AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 09, 2016 09:04AM |
JamesK
I don't think I'd want to try and use a lock nut to set the final height of a threaded throat.
Re: What is your experience with dual hotends? Are they worth the trouble? May 09, 2016 09:16AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 09, 2016 09:22AM |
I dunno, over a decade machining things for a living and experience adjusting things by .0005" or less.Quote
realthor
JamesK
Do you expect that one will not be able to fasten the nut without moving the threaded barrel just enough to invalidate the level of the 2 nozzles?
Do you expect vibrations to affect such fastened jam nut?
Is there any other reason? I fail to see any difference with regards to set screws in the final result aside from aspect and having the nozzle further away from the heatsink which I also don't know how/if it affects anything. And a tad more difficulty but considering that most of the people out there have this kind of hotends and they'd prefer to keep thaer carriages as they are, this seems like a very minimalist approach.
Thanks.
Re: What is your experience with dual hotends? Are they worth the trouble? May 09, 2016 09:25AM |
JamesK
Just based on the practical difficulty of tightening a lock nut sufficiently without moving the throat. Like you say, once tightened it should be fine, but it might be quite hard to get it in the right place. The vertical alignment of the nozzles really is quite finicky. A lot depends on how often you expect to change hotends. If the answer is almost never then you could probably make a jig and set the nozzle heights away from the printer where it would be easier to tighten a lock nut. I change hotends frequently, so I was hoping for a system that is quick and easy to do in situ.
The other minor disadvantage of a thread throat is that adjusting the height means rotating the hotend, so you can't rely on any particular orientation of the heater block without also having to adjust the nozzle/heatblock relationship. Smooth throats seem to be a more natural approach for a dual extruder setup.
Anonymous User
Re: What is your experience with dual hotends? Are they worth the trouble? May 12, 2016 07:41AM |
Koko76
Me personally? None. I strongly considered building my new machine around a dual extruder design, mainly for the purpose of printing dissolvable support material. I ultimately decided against designing around it for a number of reasons. Mainly that to me the compromises needed to make dual extrusion happen would impact print quality with a single nozzle in ways I didn't want.Quote
JamesK
Koko76
Look at existing work. E3d is nice enough to publish drawings of already working designs.
Which designs did you have in mind?
The E3D designs are the Chimera and Cyclops (the Kracken also uses a similar arrangement). They use a smooth walled heatbreak tube instead of the v6 threaded version where the heatbreak attaches to the heatsink. They use a set screw, to fix the tube in the hole and allow adjustments. They seem to hold reasonable tolerances, so I imagine the fit is fine. Were I to do it, I would wire cut a clamp block, but consumers are typically unwilling to pay the price that wire edm part would cost, so I can see why they did it that way. Something similar to a one piece shaft collar could work here. They do make aluminum ones.
Theory is one thing, but actually adjusting something like this to work in the real world is a different matter. Tightening threads against each other is generally very very fiddly.
Anonymous User
Re: What is your experience with dual hotends? Are they worth the trouble? May 12, 2016 07:50AM |
realthor
JamesK
Thanks.
Re: What is your experience with dual hotends? Are they worth the trouble? May 12, 2016 07:57AM |
