Infill Uses Two Axis May 13, 2016 03:10PM |
. Would someone be kind enough to explain why the infill lines [square infill type] are at 45* and -45 to the x-plain and not straight up and down [0* and 90*]. At the moment my printer moves both the x and y axis to create each infill line, I believe it would be faster if it moved just one axis for each infill line, but I'm sure there will be a reason it is printing in this way.|
Re: Infill Uses Two Axis May 13, 2016 04:42PM |
Re: Infill Uses Two Axis May 13, 2016 06:42PM |
Re: Infill Uses Two Axis May 13, 2016 06:49PM |
Re: Infill Uses Two Axis May 14, 2016 09:39AM |
Good to know.|
Re: Infill Uses Two Axis May 14, 2016 10:02AM |
No, that is only correct if the axis were moving at their speed limits before you switched the angle. As I said above, using one axis or two in this case is NOT limiting your infill speed, only in the edge case that you were at the machines maximum speed in a single axis to start. Let's start with some basics, what speed do you have set in your slicer for perimeters? What speed do you have set for infill?Quote
m.ratcliffe
Thanks for the replies I appreciate it, I will try a few prints with the setting changed and see how it effects print time.
If I am understanding the theory correctly, by using two axis im printing the infill 1.4 times faster with the same motor speedGood to know.
Re: Infill Uses Two Axis May 14, 2016 11:00AM |
Re: Infill Uses Two Axis May 14, 2016 12:09PM |
