Thermistor not working
Posted by leomireles007
May 14, 2016 07:03PM
I was being given very high temp readings from repetier coming from my just built 3d printer and I thought the problem was the thermistor. After a lot of checking I decided to unplug both the hot end and heated bed thermistor to see what could happen and to my surprise, Repetier still kepps giving me very high temperatures, and the values change. So I don't know whats wrong now. Any ideas?
Edited 1 time(s). Last edit at 05/14/2016 07:13PM by leomireles007.
Re: Thermistor not working
May 15, 2016 08:40PM
try swapping thermistor location at the board did the printer come preloaded with firmware or user loaded could be firmware related if sensors are good
May 16, 2016 12:39PM
Ok so I was messing with the firmware configuration.h file and got both the hot end and the heated bed to read properly but after printing something the bed started to read the same as the hot end and now that I heat the bed nothing happens but when I heat the hot end the bed readings rise too, which means the heated bed thermistor is not working and is replacing its values for the ones of the hot end. This is making me crazy
Edited 1 time(s). Last edit at 05/16/2016 12:40PM by leomireles007.
