I need help with buying a 3D printer May 17, 2016 11:48PM |
Re: I need help with buying a 3D printer May 18, 2016 03:22AM |
Re: I need help with buying a 3D printer May 18, 2016 12:22PM |
Re: I need help with buying a 3D printer May 18, 2016 08:25PM |
Re: I need help with buying a 3D printer May 19, 2016 08:20AM |
nebbian
I'd avoid Delta printers like that one. You'd be better off with a cartesian printer that has a print bed of at least 200mm in one direction. I'd also go with a heated bed. Investigate PETg as a material for printing drone parts, PLA is too brittle (and heat intolerant), while ABS warps when printing larger parts.
Sgriff08
As Nebbian said, you are probably not looking for a delta printer, I have a delta and it's very heavy on calibration and can be a bit overwhelming for a first printer. You would be best looking at a Mandle design, the Prusa i3 is pretty much bullet proof. When sourcing these kits it's important to keep in mind the quality of the parts, as an example, in my design process I tested almost 20 different bearing manufacturers before settling on my supplier.
I recommend a Prusa for ease of use and functionality, moving from there you can find a kit that fits your budget or source yourself.
You can print drone parts in both PLA and ABS, however, you will want to design and print these parts for your application; PLA can be very strong depending on how you design the part. Additionally, ABS does warp on larger parts, however, this is easily solved with a good bed level and adding 2-3 layer thick "tags" to the corners of your model to prevent lifting...also...hairspray... .
Good luck!
Re: I need help with buying a 3D printer May 19, 2016 01:39PM |
I will also be doing more extensive research into plastics and will probably be mixing and matching them for different parts of the plane.
Re: I need help with buying a 3D printer May 23, 2016 11:54PM |
Re: I need help with buying a 3D printer May 24, 2016 12:48AM |
