Powering Reprap using both 12v & 5v ATX lines May 18, 2016 10:43AM |
Re: Powering Reprap using both 12v & 5v ATX lines May 18, 2016 01:59PM |
Re: Powering Reprap using both 12v & 5v ATX lines May 18, 2016 02:35PM |
A_Designs
Since the 5v line needs a load
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Powering Reprap using both 12v & 5v ATX lines May 18, 2016 08:14PM |
JamesK
You'll need a high current boost converter which sounds expensive, and when the bed cycles (which it will) your 12v line will lose regulation. I wouldn't recommend this approach. You can use a modest boost converter to generate 8V from the 5V line and use that to power the mega2560. You'll likely still need some heavier load on the 5V line to help the regulation, unless you modify the PSU internals. For the bed size you mention you will probably be better off with a silicone mat heater running off either mains or 24V.
My PSU is a couple years old(Read 5+ ) with moderate use, so I'm guessing it would need the 5v loading. Also, I'm buying the above linked PCB, not building a custom one.Quote
Traumflug
A_Designs
Some older PSUs needs this load, most, especially more modern ones, don't.
One way to get such a load from the heated bed would be a bed with with two heating track loops. One constantly/unregulated fed by 5 V and the other one regulated and fed by 12 V. Worth a thought if you're going to make a custom heating PCB anyways.
Re: Powering Reprap using both 12v & 5v ATX lines May 18, 2016 08:23PM |
A_Designs
Re: Powering Reprap using both 12v & 5v ATX lines May 18, 2016 09:17PM |
Re: Powering Reprap using both 12v & 5v ATX lines May 19, 2016 03:34AM |
JamesK
It's a bit disappointing that they don't specify the power consumption on that pcb. Makes it hard to plan for.
So I calculated that the resistance should be 1.1 ohms. How much current do 300mm heatbed PCBs normally draw?Quote
It draws approx 11 Amp currnet, when 12 Volt input is supplied. So power is approx = 131 Watt. It is made with 2mm Thick aluminium base
Re: Powering Reprap using both 12v & 5v ATX lines May 19, 2016 03:55AM |
Re: Powering Reprap using both 12v & 5v ATX lines May 19, 2016 04:00AM |
Re: Powering Reprap using both 12v & 5v ATX lines May 19, 2016 06:12AM |
A_Designs
JamesK
Yes, so I mailed them about it, and they replied
