The sounds of silence May 18, 2016 02:50PM |
Re: The sounds of silence May 18, 2016 03:03PM |
Re: The sounds of silence May 18, 2016 05:59PM |
Re: The sounds of silence May 18, 2016 06:17PM |
Re: The sounds of silence May 18, 2016 06:29PM |
Re: The sounds of silence May 19, 2016 03:31PM |
drmaestro
Switching to silent stepstick is the best thing to do, as it practically silences the steppers. I can only hear the power supply fan when my printer is working. However they are more difficult to install due to their configurable nature and also need good cooling (I had to revert back on the Z axis to 4988 as it was getting too hot but I've ordered 2 80 mm fans, so I'll have better cooling and reinstall them).
Re: The sounds of silence May 19, 2016 06:12PM |
vpt5566
drmaestro
With the silent stepsticks, do you get a high pitch noise coming through your steppers when they are not moving?
Re: The sounds of silence May 20, 2016 09:09AM |
drmaestro
vpt5566
drmaestro
No, I don't get any high pitched noise. I know that I am supposed to hear some, as I am using a 12 volt power supply. I think that my steppers are configured to work on stealthChop mode (I did remove all of the microstepping pins on the RAMPS, but didn't remove any header pins from the silent Stepstick, and didn't make a connection between the third pin and the ground pin. From what I can find on Internet, these conditions activate the stealthChop mode). Normally, the stealthChop mode shouldn't be able to run a 3d printer stepper but it does in my case (and if I am somehow running on spreadCycle mode, I can't imagine how silent stealthChop mode ise, as I practically can't hear any noise form the steppers). The only problem I had with the silentStepstick was on the Z axis, as the driver became very very hot and unstable, so I had to replace it with a 4988. I am waiting for some 60 mm cooling fans to provide better cooling to RAMPS, then I'll replace them again.
Re: The sounds of silence May 20, 2016 01:07PM |
Re: The sounds of silence May 20, 2016 04:07PM |
Re: The sounds of silence May 20, 2016 05:38PM |
Re: The sounds of silence May 21, 2016 07:07PM |
sungod3k
The loudest element by far is my hotend cooling fan. Any attempts to get bigger slower spinning fans on an e3d mount?
Re: The sounds of silence May 22, 2016 07:25PM |
bryanandaimee
The other thing I'm researching is firmware.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: The sounds of silence May 23, 2016 01:02PM |
Re: The sounds of silence May 23, 2016 09:56PM |
bryanandaimee
Do you have an idea what the differences are between firmware that might affect the noise?
Re: The sounds of silence May 24, 2016 01:02AM |
Traumflug
bryanandaimee
The only thing I can think of is uneven step distribution. A firmware does not more than sending a few pulses out of an I/O pin, after all.
