heating bed thermistor
Posted by burton2663
May 29, 2016 12:55PM
I have a sanguinlolu board, tested the heater bed voltage output its not working. I cant make my filament stick to the glass, using sticky glue and hairspray. Is the MOSFET damaged? How to troubleshoot the board? The connector has a wire burned.
Thanks
open | download - 13265951_10209126456175713_1026835516401374514_n.jpg (41.8 KB)
open | download - 13335843_10209126455935707_7687717472485245064_n.jpg (63.2 KB)
Re: heating bed thermistor
May 31, 2016 10:03AM
These KK256 connectors are rated for 1 Ampére, a typical heated bed needs 10 times of that. Sanguinololus are severely undersized in this area and your specimen doesn't even use the 4 pins available by design. To get the bed working you need a Solid State Relay, e.g. a SevenSwitch.
