Need Help for my Project 3d printer May 30, 2016 07:58AM |
Re: Need Help for my Project 3d printer May 31, 2016 12:21AM |
Re: Need Help for my Project 3d printer May 31, 2016 06:56AM |
Re: Need Help for my Project 3d printer May 31, 2016 09:02AM |
Re: Need Help for my Project 3d printer June 02, 2016 10:51AM |
Re: Need Help for my Project 3d printer June 02, 2016 01:21PM |
Re: Need Help for my Project 3d printer June 02, 2016 01:28PM |
Re: Need Help for my Project 3d printer June 03, 2016 09:32PM |
Re: Need Help for my Project 3d printer June 08, 2016 07:30AM |
Re: Need Help for my Project 3d printer June 10, 2016 09:49AM |
Lymphomaniac1
DC42:
Let's do the math. The heater draws 300W. 12V X 40A = 480 VA or W. A SSR-40DD should handle 300W.
laco has to deal with what he has, a 300W bed heater (I hope it is rated for 12V if he has a 12V power supply), a 12V power supply, and a SSR-40DD. He may get a drop in voltage, but it is what he has and so his heat bed may take a little longer to heat up. When I built my printer, I used a 110VAC bed heater rated at 280W and a SSR-40DA. I think working with the mains power works much better in that my bed heats up a lot faster than when I used a DC setup.
If laco wants to invest in a better system, I would recommend that he picks up a AC bed heater compatible with the mains power where he lives along with a SSR-40DA. I would also suggest that the heater have a hole in the center so that he can attach the thermistor directly to the aluminum build plate for better readings. Keenovo (www.keenovo.com) sells silicone heaters for every occasion either on their website or on ebay. If he can not find exactly what you want, they will make it for him. They have quality 12VDC, 24VDC, 110VAC and 220VAC silicone heaters.
Stuart
Re: Need Help for my Project 3d printer June 30, 2016 01:48PM |
