DealExtreme Kapton
Posted by An Original Name
DealExtreme Kapton
November 24, 2010 05:14PM
Has anyone purchased the kapton tape from dealextreme recently? I heard they were selling faulty/fake kapton; are they still selling this bad tape or have they stopped?
Re: DealExtreme Kapton
November 24, 2010 07:14PM
Not sure what you're talking about. I bought mine back in May and other than some rips that occur just after cleaning when pieces get stuck to the bed like glue I haven't had any problems with it. I wind my nichrome with it too. confused smiley
November 24, 2010 07:33PM
Make sure to check when it arrives. Mine was fine.
That said, also make sure to check the specs on their page suits what you're doing.
For covering a heated bed, 260 Deg C "should" be fine, but I wouldn't use it for a heating element. DX also have 10mm wide stuff that goes to 300 Deg C that so far lives up to all the expectations I've put on it.
That said, the thing that separates most cheap Kapton from the good stuff is the quality of the adhesive on the tape. Many of the cheap tapes (Deal Extreme included) do not use a proper high temp grade adhesive. I must admit that the 10mm DX stuff at least stays stuck to itself after going above 200 Deg C, which is better than some I've seen.
Note: Remember, the tape is a plastic, and as such it expands a LOT faster than metal or ceramic as it gets hot. As such, it will lift off surfaces when it heats up if the adhesive isn't up to the job. Even then, it can still crinkle.
November 24, 2010 07:47PM
http://reprap.org/wiki/Kapton_tape
WARNING: Some of the tape from this company is fake. It cannot handle the temperatures needed for the RepRap project.
Also here: [www.dealextreme.com] .
That's what I'm referring to. But, if they're not shipping bad kapton anymore, it's all good. grinning smiley
Edited 1 time(s). Last edit at 11/24/2010 07:50PM by An Original Name.
November 24, 2010 08:17PM
I have three rolls of different kapton widths from dealextreme, they all pass the soldering iron test. The PET and PTFE tape they have is also good. Of course there's always a possibility of a bad batch, though for me the price is worth the "risk". But this worry is blown out of proportion as you will most probable get a refund if you ask politely.
-Nudel
Blog with RepRap Comic
November 25, 2010 12:01AM
I use DX PET and Kapton tape and use tons of it, but I ONLY use it for my heated build platform surface, not for any thing where I need 'real' kapton.
December 04, 2010 12:59PM
instead of buying from Dealextreme you can try a better one , online shop from china !
its Chinabuye which has better service and verified suppliers !!
December 04, 2010 01:45PM
lol - sorry for being cynical but someone that signs on today and his first post is to plug a sales site?
eye rolling smiley
Edited 1 time(s). Last edit at 12/04/2010 01:45PM by AgeingHippy.
December 04, 2010 10:43PM
And a site which doesn't even have any kind of tape for sale. tongue sticking out smiley
-Nudel
February 14, 2011 06:30PM
Well, here's an update.. I was dumb enough not to test DX kapton with a soldering iron first! I put it on my extruder thinking it would work (rated at 300C), but it melted at less than 200C! In addition, as soon as I tested it with a hot soldering iron, it melted instantly. What's weird is that my other roll (which I think was rated at 260C or 200C) actually withstood the soldering iron. Maybe I could use that instead. I'm still upset about having to replace my thermistor (one of the lead wires broke off while I was trying to salvage it from the mess), and I really do hope nothing on my Gen6 board fried because of this!! I turned the heat off pretty quick after I noticed my nozzle smoking, but I'm not sure if anything else was damaged until I can get another thermistor.
