Re: PEI vs. BuildTak vs. PrintBite November 03, 2017 07:26AM |
Re: PEI vs. BuildTak vs. PrintBite November 03, 2017 04:03PM |
Re: PEI vs. BuildTak vs. PrintBite November 04, 2017 11:08AM |
Re: PEI vs. BuildTak vs. PrintBite November 04, 2017 01:24PM |
DjDemonD
Okay so no name black ABS from go-inks (the white one was printed about a year ago so no idea although I was using quite a bit of Excelvan which is not available anymore - which is a great shame).
Using Prusa slic3r for the black one probably 2 perimeters and no infill, to try to minimise the amount of material causing contraction as it cools.
Light wash of abs juice really quite dilute.
Here they are:
[attachment 99343 20171101_193252.jpg]
But my results with 10% infill below didn't show an improvement. Go-inks availability is a prob in the US. Could that be the magic?Quote
ECJ
Dilute 0.5 grams of "dental acrylic powder" into 15 grams of ABS juice and then tell us the result... Intructions:
Add the powder on the juice and stir / shake vigorously. Let stand for 2 hours and then stir / shake again. It will be ready to use.
It gives good results even on a glass table. But it should be spread on the heated desk at about 45 degrees to repel moisture that can spoil the effectiveness of the film.
Re: PEI vs. BuildTak vs. PrintBite November 04, 2017 03:40PM |
Re: PEI vs. BuildTak vs. PrintBite November 04, 2017 06:59PM |
to-the-nth
I love this. First thing that came to mind was 007 "Shaken, not stirred". I am fresh out of dental acrylic. 2 hour prep is a PITA, but if the result is magical, it might be worth the wait. What is the theory behind this and what kind of results are you seeing? what brand of acrylic powder? Prime? release on cooling? pulls glass chips? what brand ABS?
Various brands
Re: PEI vs. BuildTak vs. PrintBite November 11, 2017 03:47PM |
Re: PEI vs. BuildTak vs. PrintBite November 21, 2017 01:41AM |
Re: PEI vs. BuildTak vs. PrintBite November 21, 2017 09:45AM |
