Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 12, 2016 04:50PM |
MechaBits
Lol...Just put X arm on a hinge...then you might only need to level bed in one direction.
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 12, 2016 05:01PM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 12, 2016 05:08PM |
DjDemonD
They might bend if you are fortunate enough to have your head crash in the centre of their travel, but near the supports at the ends of the travel - probably not a great deal at all.
Sorry to be a little puzzled at this topic but head crashes are occasional unfortunate events, which generally don't cause much harm as they usually only happen when calibrating/modifying the machine and something is not set right, often during these events you are watching closely and can pull the plug before anything snaps. Electronics failures happen too, but with NC sensors, a failed sensor (or broken wire/connector) results in no z movement, and in my experience this is the most likely and common electronic failure leading to a head crash. Whilst a system that can prevent any head crashes would be nice if it were simple and reliable aren't we trying to force a solution where there is little or no problem to begin with?
I have a belt driven z axis so if I get my motor torque just right, then the z motor skips on a head crash instead of the heatbreak (or any other part of the print head) breaking/bending. Less easy to do with leadscrews/ballscrews I agree due to their gearing but still possible.
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 12, 2016 05:18PM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 12, 2016 05:49PM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 12, 2016 05:56PM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 12, 2016 06:33PM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one June 13, 2016 03:59AM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one July 04, 2016 05:05AM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one July 04, 2016 05:43AM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one July 04, 2016 06:07AM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one July 04, 2016 08:54AM |
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one July 04, 2016 08:55AM |
Milton
So has anyone made a vertical brace for the edges of a heat bed that allows it to travel vertically but not horizontally in relation to the Y carriage? I am printing tests of that, but are there any known issues there? Like 'oh man everyone did that 3 years ago but it causes X horrible problem!' type info is sorta what I am after here, as well as any and all good advice.
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one July 04, 2016 10:59AM |
lhartmann
P.s. Loved the piezo auto leveling. Where can I find more details on the hardware/firmware?
Re: Bed Stability: 3-point leveling should be in fact 2-point leveling and a fixed one July 04, 2016 01:56PM |
