E3D V6 Nozzles are completely different from technical drawing June 02, 2016 04:37PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 07:23PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 07:33PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 08:27PM |
Custom cutters get made all the time, we get them from time to time at work. Cost is not that much more than standard cutters, especially if you buy a few.Quote
ElmoC
They could also get the same two step bore with a special bit that has a cutter with both the A and D dimensions. Might be costly to get made, but could pay for itself in reduced labor.
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 08:40PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 08:43PM |
JamesK
Hadn't thought of that - showing my ignorance. Which does make you wonder why they simplified the design.
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 08:45PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 08:48PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 02, 2016 08:50PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 03, 2016 07:01PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 07, 2016 11:36AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 07, 2016 11:47AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 04:33AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 04:45AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 05:48AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 07:53AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 08:10AM |
3) How does the geometric difference between the two different versions affect "back-pressure"?
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 09:22AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 09:26AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 12:02PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 12:35PM |
I've made a significant number of gates for multi cavity injection molds. Amongst many critical dimensions (lots of these are +/-.0002" or so) is the dimension being discussed here. In the particular one I'm thinking of the actual flat area of land is around .005" long and is absolutely critical to function. The length of the land of that diameter absolutely does matter in squirting molten plastic the way you want it squirted. I don't have the specific math on hand to quantify it, but simply changing pressure or temperature can't overcome the physics that happen in this particular region.Quote
the_digital_dentist
It's nice to look at the physics but without a deeper understanding of high temperature/pressure viscous fluid flow, and in the complete absence of data, a guess is just a guess.
Which brings me back to the first question: what constitutes a back pressure problem? How do you distinguish it from a too low temperature problem? Or a too low extruder push problem? Or a filament formulation problem?
If the filament won't flow, turn up the temperature to reduce viscosity and/or apply more pressure from the extruder (increased current, add a gear box, bigger motor, etc.). If that still doesn't do it, use thicker print layers and a bigger nozzle.
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 12:41PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 02:55PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 03:02PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 10, 2016 03:29PM |
Re: E3D V6 Nozzles are completely different from technical drawing June 28, 2016 07:49AM |
the_digital_dentist
Sergio,
in your first post you said you had a "back-pressure problem" and in the last one you said you originally bought these nozzles specifically to reduce "back-pressure".
Three questions:
1) What constitutes a "back-pressure problem"?
2) How would anyone know that they have a "back-pressure" problem and not some other problem?
Re: E3D V6 Nozzles are completely different from technical drawing June 28, 2016 08:36AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 28, 2016 09:21AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 29, 2016 04:50AM |
Re: E3D V6 Nozzles are completely different from technical drawing June 29, 2016 02:51PM |
