Bonding GT2 belts June 03, 2016 10:02AM |
Re: Bonding GT2 belts June 03, 2016 10:09AM |
Re: Bonding GT2 belts June 03, 2016 10:40AM |
Re: Bonding GT2 belts June 03, 2016 10:48AM |
Re: Bonding GT2 belts June 03, 2016 10:58AM |
Re: Bonding GT2 belts June 03, 2016 10:59AM |
Re: Bonding GT2 belts June 03, 2016 11:06AM |
Re: Bonding GT2 belts June 03, 2016 12:01PM |
Re: Bonding GT2 belts June 03, 2016 12:17PM |
Re: Bonding GT2 belts June 03, 2016 12:19PM |
Re: Bonding GT2 belts June 03, 2016 12:28PM |
Re: Bonding GT2 belts June 03, 2016 02:27PM |
Koko76
Check Loctite's website. They have several CA formulas optimized specifically for rubber, higher peel strength and higher flexibility. They work OK.
Re: Bonding GT2 belts June 03, 2016 03:46PM |
Re: Bonding GT2 belts June 03, 2016 04:05PM |
Re: Bonding GT2 belts June 03, 2016 10:52PM |
Re: Bonding GT2 belts June 03, 2016 11:32PM |
Re: Bonding GT2 belts June 03, 2016 11:41PM |
Mutley3D
why not two small cable ties?
Re: Bonding GT2 belts June 04, 2016 01:22AM |
Re: Bonding GT2 belts June 04, 2016 05:15AM |
Re: Bonding GT2 belts June 07, 2016 11:06AM |
Re: Bonding GT2 belts April 30, 2020 05:40AM |
Re: Bonding GT2 belts May 01, 2020 02:43AM |
Re: Bonding GT2 belts May 01, 2020 06:22AM |
etfrench
A toothed pulley with an 8mm bore, several MF85zz bearings, and a 5mm shoulder bolt would be simpler
Re: Bonding GT2 belts May 01, 2020 06:46AM |
Re: Bonding GT2 belts May 01, 2020 07:47AM |
Re: Bonding GT2 belts May 01, 2020 08:12AM |
the_digital_dentist
Can you be specific about exacly what type of glue you used? All the cyanoacrylate glue I've ever used crumbles into dust when you put it on something flexible and then flex it.
Re: Bonding GT2 belts May 01, 2020 09:58AM |
