Pancake stepper extruder
Posted by Origamib
NSTT
November 19, 2017 11:19PM
Food for thought NSTT, Assembly, Assembly (old?), Time to order some pancakes and start CAD'ing
Edited 2 time(s). Last edit at 11/19/2017 11:37PM by to-the-nth.
Re: Pancake stepper extruder
November 20, 2017 03:04AM
The Bowden extruder I'm using is a printed extruder and it works OK. The weakest link in my case is the mount for the E3D /volcano hotend. I'm currently building a CNC-mill because of this. Printing precise PETG parts is difficult, because retraction causes blobs, so I'll give the Titan a try. PETG prints are slow anyway, so a little extra weight doesn't matter.
My D-bot isn't standard as well. I have plenty of spare room to direct mount the Titan without loosing workspace.
I also have an idea for an automated belt_tension_equalizer. It allows to control both belts tension with one screw. Maybe a complete reconstruction will come soon.
November 20, 2017 08:29AM
Cant wait to see the Sanyo Pancake all mounted up, I wanted to try one but not at the price they where when I last looked.
November 21, 2017 12:41AM
Ditto on the Sanyo price, but interesting.
o_lampe
I've got rolls of PETG sitting in closet because of blobs. If you figure out how to disappear the blobs and strings, let me know. Everyone should have a CNC-mill in their workshop, but it might be easier to add a chamber to your D-bot and print ABS. I had plenty of spare room on my "D-bot" but I just made the bed larger. I found individual tensioning adjustment screws on each XY stepper work really well.
It's probably too off topic to talk about Titan alternatives like NSTT here, so I'll start a new thread when I get something running. Pancakes are on order. Printed the NSTT gears for reference. The gears are 1.0-mod but the pressure angle is steeper than what I have been using. Overall looks credible, but I'll be designing something that is more vertical and sits above the X carriage plate. Using the lighter 17HS08-1004S stepper, so might increase the gear ratio. Small compact doesn't matter, just the weight and cost.
November 21, 2017 01:55AM
[www.thingiverse.com]
September 22, 2022 06:35AM
yes, ... the size depends on possible speed and gearbox-ratio, best would be a small DC-motor with encoder.
i just got several pancake stepper motor from here:
https://www.oyostepper.com/category-64-b0-Pancake-Stepper-Motor.html
rq3
September 22, 2022 10:28AM
jianbagn21
[reprap.org]
With the mounting ears cut off, and the case lightened. I don't suggest this, as the case is almost foil thin in that area, the weight savings is negligable, it allows contaminants into the motor, and dis-assembly and re-assembly is critical.
Edited 1 time(s). Last edit at 09/22/2022 12:31PM by rq3.
open | download - VDE_Imperial_Grams.jpg (532.4 KB)
