temperature which first and second
Posted by 3D rob
June 11, 2016 04:33PM
is it possible
in order to let it come bed up to temperature (as the initial/ as first)
and that then the extruder comes up to temperature.
Now the LCD simultaneously turns on(The extruder is the first hot)
now with the LCD goes all the heating at the same time.
I think it is better to bed first on temperature,
that thereafter the extruder comes on temperature
Greetings from the Netherlands.
Rob.
Re: temperature which first and second
June 11, 2016 09:34PM
There are two commands to set the temperature. M140 sets the bed temperature then immediately returns control to the host/controller. M190 sets the temperature and waits until the bed reaches that temperature before returning control to host/controller.
If you use the M190 command to set the bed temperature first then use M109 to set the extruder temperature, the bed temperature will be reached before the extruder heater is turned on. Then the extruder will turn on and it will wait until it has reached target temperature before printing will start.
See [reprap.org]
June 12, 2016 04:53PM
thanks digital_dentist,
the next question you might be surprised.grinning smiley
How do I get the M190 and M109 in the LCD?
(Via Marlin? / Enter at marlin? If so, where in marlin?)
I've only recently connected the LCD,
I have 2 videos viewed how to do it (so I have done it a lot)
and yes software is indeed my worst side!
I'd rather build (fast) a printer
[myalbum.com]
thanks for the reply and the friendly greetings from the Netherlands (Rotterdam)
Rob.
June 12, 2016 05:28PM
The slicer that prepares the files for printing should use those commands to set the temperature. Slic3r uses M190 for the bed temperature then uses M104 (I have no idea why) followed by M109 to set extruder temperature. Other slicers should do similar...
June 12, 2016 06:17PM
I actually had this..... must known by myself
I really should have known this for myself, of course,
and yes now that you mention it ......in slicer.
to erase my fault a little winking smiley
I had also problems to understand youre writing now.
And I hope that my writing to you is a little readable/understandable.
glad you had the patience to help me here, thank you for that!thumbs up
Greetings and you too have fun with the hobby!
Rob.
