Um, if there's a 5C offset, set the bed temperature 5C higher.
My bed heater reads 95C when the print surface is actually at 105C. It doesn't bother me enough to use a different thermistor or try to edit the thermistor table. I just set the printer to 95 when I want the bed to be 105C for printing ABS.
There are so many different thermistors in use that you really can't trust the temperature readings from the controller. I think that a lot of the companies who make heaters with integral thermistors use whichever thermistors they can buy cheaply. You have to experiment a bit to see what temperature settings work.
Ultra MegaMax Dominator 3D printer: [
drmrehorst.blogspot.com]
