Filament feed indicator idea. June 17, 2016 07:55AM |
Re: Filament feed indicator idea. June 17, 2016 08:37AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Filament feed indicator idea. June 17, 2016 10:05AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Filament feed indicator idea. June 17, 2016 04:00PM |
Re: Filament feed indicator idea. June 18, 2016 03:11AM |
Re: Filament feed indicator idea. June 18, 2016 04:48AM |
Re: Filament feed indicator idea. June 18, 2016 09:51AM |
Re: Filament feed indicator idea. June 18, 2016 01:09PM |
Re: Filament feed indicator idea. June 18, 2016 03:13PM |
cozmicray
WHY?
What will happen when a filament advance failure?
Will you be matching measured filament movement with commanded movement.
Will you account for retraction? and recovery after retraction.
A failure of filament advance:
---- pause print
----- run full diagnostic routine on extruder
flash LED
sound buzzer
---- move ruined print off bed --- restart print
Yes discovery of filament movement failure is great
but what to do next --- the real challenge
Re: Filament feed indicator idea. June 19, 2016 01:32PM |
leadinglights
One of the most severe outcomes of a failure to feed filament through the hot end is that it has been fed out of the extruder through a gap between the extruder body and the idler carrier resulting in the loss of quite a bit of a 1kg roll of Ninjaflex.
Re: Filament feed indicator idea. June 19, 2016 01:44PM |
Re: Filament feed indicator idea. June 19, 2016 02:26PM |
Re: Filament feed indicator idea. June 19, 2016 02:41PM |
Re: Filament feed indicator idea. June 19, 2016 05:47PM |
leadinglights
The lower part of the green line shows where the filament went out sideways past the bearing. Motion detectors which look at the filament before the extruder would miss the failure shown above.
Re: Filament feed indicator idea. June 20, 2016 03:51AM |
cozmicray
Right your getting so much feedback --- I won't comment anymore!!!
Re: Filament feed indicator idea. February 15, 2017 11:42PM |
Re: Filament feed indicator idea. February 15, 2017 11:47PM |
Re: Filament feed indicator idea. February 16, 2017 03:09AM |
Re: Filament feed indicator idea. February 16, 2017 03:34AM |
Re: Filament feed indicator idea. February 16, 2017 03:58AM |
o_lampe
I doubt that an optical mouse sensor can detect the non existent dents in super soft black TPU/TPE filament. ( the only flex filament I've tried so far )
Re: Filament feed indicator idea. February 16, 2017 05:20AM |
Re: Filament feed indicator idea. February 16, 2017 08:49AM |
And I had it down with the great cozmic mysteries along with dark matter, dark energy and oh so many things.Quote
DjDemonD
I think I can see what cozmicray is saying....
My main interest is in getting a diagnostic record - it is easier to take the right action or make design changes if you have good evidence that if you are just left with your best guess. In the case of the filament feed indicator: Were there periods of poor feeding? If the print failed, what happened immediately before?Quote
Is this to stop/pause the print if filament/hotend jams, kinks, gets tangled on the spool, all of the usual causes of returning to a mess rather than a beautiful object - or is this an attempt at closed loop filament control?
