Using a DC booster for 24V on the heated bed only June 19, 2016 04:15PM |
Re: Using a DC booster for 24V on the heated bed only June 19, 2016 05:27PM |
Re: Using a DC booster for 24V on the heated bed only June 19, 2016 08:19PM |
DjDemonD
So the device you show above is a step up transformer 12v dc to 24v dc? I am not sure that's the right way to go, you will still have to supply it via the ramps board so you're still pulling 11A through the ramps, and we all know how much they like that, and that's your limit.
The way I did this for my enlarged smartrapcore alu with 300x200 bed is to run the heated bed output to a fused automotive mechanical relay, set bang bang control in the firmware so the relay isn't switching on/off too fast and then use a second 24v psu via the relay to the bed. As a result I get 250w @ 24vdc for my bed (which I have connected via its 12v connectors so it draws the maximum 12A from the 24v PSU), it heats up within 5 minutes to 120 deg C, I am not pulling 11A through the ramps board so much less worry about heat/fire/etc, and I have downgraded my 12v PSU to a laptop style unit which is more than enough for motors/hot end heater and some LEDs. The only criticism I got for this approach, which incidentally has been working flawlessly for months now, is that the relay clicking on/off would be annoying, which depends on your point of view, I like to hear it working, and I know when to go and remove the insulation from on top of the bed when I hear the relay click off at the end of heating. Plus if I wanted more power I'd just change the 24v PSU or consider going to mains heating.
Or use a DC-DC SSR to do the same as I have done above with 2 PSU's but now you can have PID control of the bed (pointless IMHO with a well insulated bed or even better an enclosed build volume - bang bang gives really good control). The SSR will usually need some sort of heatsink (so not that efficient if its losing energy as heat). They are more expensive and I am sure more prone to failure than a good ol' fashioned relay which cost a few $, so even if it does fail and it should fail-safe, I just swap in another one (I bought 2). I have used one for mains powered heating of a build chamber.
Moving everything over to 24v does have its appeal, 24v for steppers is supposed to be a much better prospect and I would consider this on a completely new printer build rather than on an upgrade to an existing 12v machine.
EDIT - you mean running this unit direct off the powersupply and then feeding its output into the bed power connector on the ramps?
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 12:54AM |
icefire
Of course, I could use a 24V PSU instead of the ATX PSU I have now, but that would mean to change practically everything: Hot end heater, fans, LED circuits, etc.
Thanks for your help!
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 07:38AM |
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 08:15AM |
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 09:40AM |
DjDemonD
aussiephil
Actually no, you could do the reverse of your original post, using a 24v -12v DC DC step down. your using a lot less current for fans, hotend, etc meaning a 100w step down unit would be heaps
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 09:48AM |
DjDemonD
Maybe it's because the printer I'm referring to is quite large but I could fit 8 power supplies in the box under it so I never really think they are that bulky and unwieldy. There must be a psu on offer from China somewhere that has 12v and 24v rails.
Maybe we could make one?
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 09:58AM |
icefire
@the_digital_dentist: Actually I intend to print more ABS than other materials. I wouldn't bother me to have to wait about 20 min to reach 110 degrees.. Do you think the heater in question wiuld be even slower? The bed size I am aiming at is approx. 240x320mm.. So I couldn't find a better alternative... Furthermore, 0,5W/cm^2 would mean about 400W for the heated bed which means about 16,5 amps of current.. the ramps will not like this without an external SSR.
icefire
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 05:52PM |
Re: Using a DC booster for 24V on the heated bed only June 20, 2016 06:08PM |
Re: Using a DC booster for 24V on the heated bed only June 21, 2016 02:56PM |
dc42
I think you will find that most good 3D printers with beds larger than 200 x 200mm use 24V-capable electronics and power everything from 24V.
Re: Using a DC booster for 24V on the heated bed only June 21, 2016 04:43PM |
Re: Using a DC booster for 24V on the heated bed only June 24, 2016 01:28PM |
Re: Using a DC booster for 24V on the heated bed only June 24, 2016 01:37PM |
Re: Using a DC booster for 24V on the heated bed only June 24, 2016 06:09PM |
Re: Using a DC booster for 24V on the heated bed only June 25, 2016 11:10AM |
Re: Using a DC booster for 24V on the heated bed only June 25, 2016 11:35AM |
Mutley3D
Maybe Traumflug can chime in on this.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Using a DC booster for 24V on the heated bed only June 26, 2016 08:53AM |
Traumflug
Current limiting on the SevenSwitch isn't the MOSFET (good for 150 A ignoring the package, good for 70 A taking the package into account) and also not the PCB (really wide tracks there), but the screw terminals. These can warm up due to not optimal contacts; make sure to use not only thick wires, but also well cleaned wire ends.
Re: Using a DC booster for 24V on the heated bed only August 19, 2016 08:45PM |
Re: Using a DC booster for 24V on the heated bed only August 20, 2016 04:06AM |
Bye bye IRLB8743. Maximum input voltage 20V.Quote
icefire
- tried with 24V input voltage, no load - everything is fine
Re: Using a DC booster for 24V on the heated bed only August 20, 2016 04:41AM |
Traumflug
Re: Using a DC booster for 24V on the heated bed only August 25, 2016 12:52PM |
Re: Using a DC booster for 24V on the heated bed only August 26, 2016 07:16PM |
icefire
DjDemonD
Yes, it is. The idea would be to do something like this:
What you suggest with an automotive relay or a solid state relay is basically the same with the additional advantage that I am not pulling that much current through the RAMPS. My question is if I could avoid using two separate power supplies and use the 12V ATX PSU with the DC DC converter on the one 12V rail. If I was to use an external relay then I could go hardcore and connect the heated bed to the mains power. The current would be considerably lower and the bed would reach 110 deg. in 2-3 min.
aussiephil
Also an interesting idea. This can work as well. A disadvantage in my case is that I don't have a working 24V PSU at the moment so I need to buy one.
