hi!
First, try uninstall it and reinstall it. You might have a older config file somewhere that is causing it to react badly.
Second, check if the filament has the same temperature configuration as before. Maybe the standard temperature for PLA has changed.
For stopping like this, it might be a communication problem too, you can check your cable.
Hope it helped!
DYZE DESIGN
Hotends, Extruders, Liquid Cooling and Accessories.
