Arduino mega and thermocouple (RAMP)tongue sticking out smiley
December 07, 2010 01:25PM
Hi mates,
I am trying to get a temperature reading with my setup:
Ardunio mega + Tonokip Firware and this brakeout board (max6675).
Has ANYONE tried using thermocouple with RAMP configuration?
It said on the PINS.H file: MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
Re: Arduino mega and thermocouple (RAMP)tongue sticking out smiley
December 12, 2010 06:28PM
someone?
December 12, 2010 07:19PM
Try the reprap-dev mailing list.
http://reprap.org/pipermail/reprap-dev/ smiling bouncing smiley
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
December 12, 2010 07:48PM
I haven't tried it yet, but members of the Melbourne RUG (Australia) are working on doing it, though with a different breakout board. Scorpia is the one currently working on it.
AFAIK, it'll be much the same setup. Will prod him about this post.
December 31, 2010 01:11PM
> about this post.
Any updates?
December 31, 2010 11:08PM
I've been playing with the RAMPS design adding in the MAX6675, ause for my main RepRap it will use this electronics setup.
As for configuration, try reading up on the RepRap firmware, it has in it code to support the MAX6675 which should be relatively easy to port over.
January 01, 2011 12:47PM
Here, you can try this out.
It uses the library that LadyADA has up, so you will have to install that first.
If you read thru her documentation for it, it should be relatively easy to make the right connections.
just remember to set the USE_THERMISTOR to false, and setup the pins that you want to use to communicate in pins.h
Edit: Attached file that I apparently missed doing the first time
Edited 1 time(s). Last edit at 01/04/2011 07:19PM by RustySpoon1121.
open | download - Tonokip_Firmware-max6675.rar (8.7 KB)
January 02, 2011 10:06PM
No updates yet (Scorpia, who was playing with it, seems to be away on holiday and no one has been able to contact him).
