Firmware bug fix July 02, 2016 01:56PM |
Re: Firmware bug fix July 02, 2016 02:14PM |
Re: Firmware bug fix July 02, 2016 02:22PM |
Re: Firmware bug fix July 02, 2016 02:58PM |
dc42
It's nice that this bug has been fixed. But as someone on the thread you referred to said, "Of course, this whole situation is pretty marginal, and if it turns out this is what is causing the problem, it's just because you're running at the ragged edge of what is feasible on the hardware".
Some people delight in trying to get the maximum performance possible out of end-of-life hardware with very limited performance. Anyone else wanting good results at high speeds should use a modern 32-bit controller board and firmware designed for it.
Re: Firmware bug fix July 02, 2016 05:06PM |
Re: Firmware bug fix July 02, 2016 05:18PM |
Re: Firmware bug fix July 02, 2016 07:15PM |
