Copper slip as thermal paste July 03, 2016 04:15PM |
Re: Copper slip as thermal paste July 03, 2016 11:31PM |
Re: Copper slip as thermal paste July 04, 2016 04:34AM |
Almost all??? Brass and even copper are also used in heater blocksQuote
cozmicray
Almost all hot ends are aluminum block with a steel threaded tube for filament.......
A brief perusal of ebay and my old cartridge cases shows no aluminium - only stainless steel.Quote
Cartridge case is commonly aluminum....
Irrelevant. Does it do the job is the only questionQuote
soft copper powder providing anti-seize agent --- NOT thermal tranfer.
And definitely not intended for use at hotend temperaturesQuote
Look at cpu thermal paste --- usually a silver oxide or silver paste specifically formulated for heat transfer.
Re: Copper slip as thermal paste July 04, 2016 07:00AM |
Re: Copper slip as thermal paste July 04, 2016 11:03AM |
Re: Copper slip as thermal paste July 04, 2016 01:18PM |
Re: Copper slip as thermal paste July 04, 2016 06:10PM |
Re: Copper slip as thermal paste July 05, 2016 12:53PM |
cozmicray
Re: Copper slip as thermal paste July 05, 2016 01:49PM |
Re: Copper slip as thermal paste July 05, 2016 04:24PM |
Re: Copper slip as thermal paste July 05, 2016 07:35PM |
deckingman
cozmicray
[www.arcticsilver.com]
Extract from the link above:
"Specifications:
Extended Temperature Limits:
Peak: –50°C to >180°C
Long-Term: –50°C to 130°C"
Looks just the job for a heater cartridge where filaments need to be heated to between about 190 and 280 deg C.
Re: Copper slip as thermal paste July 05, 2016 07:38PM |
Re: Copper slip as thermal paste July 06, 2016 01:14AM |
etfrench
deckingman
cozmicray
"Specifications:
How do you get from a limit of 130°C to using it at 280°C ?
