Issue with connceting repsnapper to printer
Posted by Tinkusharma
July 04, 2016 08:57AM
Hello,
I am trying to connect the 3d printer prusa mendal i2 by using the repsnapper, it shows me connected but i try to check it doesn't make any movement.
Please reply asap.
Thanks for the help.
Re: Issue with connceting repsnapper to printer
July 04, 2016 02:42PM
Hi!
I suggest to try with repetier or pronterface. If it doesn't work, the problem might come from your machine.
We will need more information about your printer to help you better.
DYZE DESIGN
Hotends, Extruders, Liquid Cooling and Accessories.
July 05, 2016 11:23AM
I also use the pronterface it shows me online but i try to give the movement its show me error 22. I also attached the picture of my 3d printer model. Moreover when i upload the program the led of the ramps stops lightning.
Please reply asap.
Thanks for the reply.
open | download - image.jpeg (222.8 KB)
July 06, 2016 10:22AM
Hi!
I think I found your problem. You need to supply current to your RAMPS board. There are 4 screw terminals that need to be connected to a power supply, usually a 12V PSU.
DYZE DESIGN
July 06, 2016 11:58AM
I tried to connect it by using the sprinter and the pronterface its shows me online but the motors is off, graph is responding, but when to give movement to axis its shows me something like this,
onnecting...
Sprinter
1.3.22T / 20.08.2012
start
Printer is now online.
SD Start
SD init fail
Soft PWM Init
Planner Init
Stepper Timer init
Free Ram: 4649
Plan Buffer Size:1152 / 16
X:0.00Y:0.00Z:0.10E:0.00
X:0.00Y:0.00Z:0.20E:0.00
X:0.00Y:0.00Z:0.30E:0.00
X:0.00Y:0.00Z:0.40E:0.00
X:0.00Y:0.00Z:0.50E:0.00
X:0.00Y:0.00Z:0.60E:0.00
X:0.00Y:0.00Z:0.70E:0.00
X:0.00Y:0.00Z:0.80E:0.00
X:0.00Y:0.00Z:0.90E:0.00
X:0.00Y:0.00Z:1.00E:0.00
X:0.00Y:0.00Z:1.10E:0.00
X:0.00Y:0.00Z:1.20E:0.00
X:0.00Y:0.00Z:1.30E:0.00
X:0.00Y:0.00Z:1.40E:0.00
X:0.00Y:0.00Z:1.50E:0.00
X:0.00Y:0.00Z:1.60E:0.00
X:0.00Y:0.00Z:1.70E:0.00
X:0.00Y:0.00Z:1.80E:0.00
X:0.00Y:0.00Z:1.90E:0.00
X:0.00Y:0.00Z:2.00E:0.00
X:0.00Y:0.00Z:2.10E:0.00
X:0.00Y:0.00Z:2.20E:0.00
X:0.00Y:0.00Z:2.30E:0.00
X:0.00Y:0.00Z:2.40E:0.00
X:0.00Y:0.00Z:2.50E:0.00
open | download - IMG_2475.JPG (98.4 KB)
July 06, 2016 12:05PM
even I checked the connection of the power supply its ok and shows me 12V.
