Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 06:34PM |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 07:23PM |
Admin Registered: 16 years ago Posts: 13,948 |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 07:58PM |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 08:05PM |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 08:42PM |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 09:34PM |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 09:38PM |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 05, 2016 11:01PM |
DjDemonD
However most root canal instruments k-files etc.. are tapered so careful measurement of the diameter you want at some point along the file, and only using the file up to that length should suffice. The advantage of this approach is one file might clean all your nozzles. The older type are stainless steel, the newer are nickel-titanium.
Re: Has anybody tried acupuncture needles to clean out nozzles? July 06, 2016 03:58AM |
tmorris9
So the k-file thing, is the tip smaller than .35mm? that is the nozzle size I use the most.
Re: Has anybody tried acupuncture needles to clean out nozzles? July 06, 2016 04:46PM |
Re: Has anybody tried acupuncture needles to clean out nozzles? July 11, 2016 11:51PM |
