Alternative Mosfet July 19, 2016 05:42AM |
Re: Alternative Mosfet July 19, 2016 05:53AM |
Re: Alternative Mosfet July 19, 2016 06:04AM |
Re: Alternative Mosfet July 19, 2016 06:44AM |
Re: Alternative Mosfet July 19, 2016 07:15AM |
Re: Alternative Mosfet July 19, 2016 07:57AM |
Re: Alternative Mosfet July 19, 2016 08:12AM |
DjDemonD
Why not replace the mosfet with whatever you've got lying around and then use a DC-SSR to run the hot end heater. Just offload the high current switching to something more capable. If it were the heatbed I'd say just use an automotive relay but since its a hot end you want PID control, mechanical relays won't work (wont work well anyway).
Re: Alternative Mosfet July 19, 2016 08:15AM |
Re: Alternative Mosfet July 19, 2016 12:59PM |
Re: Alternative Mosfet July 19, 2016 04:59PM |
Re: Alternative Mosfet July 19, 2016 05:40PM |
dc42
If the problem is insufficient gate drive voltage then the mosfet used on the Duet should be suitable if it is mechanically compatible. It is type IPD036N04L.
