No LED Flashing
July 19, 2016 09:21PM
Running a mega2650 R3 and a ramps 1.4 - installed marlin to mega. win7 see the mega on com5. Then added the ramps and hooked it up via USB to win7.
Repetier connects but I can't control anything. On the ramp I don't see the LEDs next to the power output flashing. BAD BOARD?
Any help would be great.
Re: No LED Flashing
July 19, 2016 10:59PM
or stepper drivers in backwards
or endstops wired from +5v to gnd shorting out the board
Re: No LED Flashing
July 20, 2016 11:51AM
Dust,
Thanks for the help. Driver in correctly, will need to check limit switches polarity.
Re: No LED Flashing
July 21, 2016 12:58PM
Same with or with out limit switches, No LED activity.
Re: No LED Flashing
July 21, 2016 12:59PM
Is there a test to see if a RAMP 1.4 board is working?
Re: No LED Flashing
July 21, 2016 01:00PM
I found this link for testing RAMPS [www.youtube.com]
Re: No LED Flashing
July 22, 2016 01:46AM
Use pronterface instead of repetier. Pronterface is for marlin, repetier host is for repetier firmware.
Re: No LED Flashing
July 22, 2016 10:24AM
nebbian,
Oh! will download Pronterface and try, thanks
Re: No LED Flashing
July 22, 2016 11:40AM
Meh, I use repetier host with Marlin firmware on my Mega/Ramps setup. It works, prints, etc... Some of the features like upload to the SD card might not work, but it works fine as a control and printing host. I actually use it to create a build plate, then let Repetier host slice it through slic3r since Slic3r likes to crash when you move or rearrange parts too quickly.. I really didn't like Pronterface.
Re: No LED Flashing
July 22, 2016 12:05PM
PDBeal,
Yeah, I was wondering about repetier being the cause of my issues. The old control board that I'm replacing was not an arduino and it's firmware was stuck using repetier 1.06. I was really looking forward to upgrading to the latest RH with this rebuild I'm doing on my 3d printer. I just wish I could get the RAMPs to respond.
thanks for the input PDBeal
Edited 1 time(s). Last edit at 07/22/2016 12:05PM by othoap.
Re: No LED Flashing
July 25, 2016 10:48PM
Just got my new RAMPs board and still can't control a stepper with repetier or pronter. Arduino can upload blink or marlin. I see mega on com5. I only have one stepper connected to X. Do I need to hook everything up just to test RAMPs?
here's the out of pronter:
Connecting...
start
Printer is now online.
echo:Marlin 1.1.0-RC6
echo: Last Updated: 2016-04-24 12:00 | Author: (none, default config)
Compiled: Jul 25 2016
echo: Free Memory: 5212 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echoconfused smileyteps per unit:
echo: M92 X80.00 Y80.00 Z4000.00 E500.00
echo:Maximum feedrates (mm/s):
echo: M203 X300.00 Y300.00 Z5.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X3000 Y3000 Z100 E10000
echo:Accelerations: P=printing, R=retract and T=travel
echo: M204 P3000.00 R3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echotongue sticking out smileyID settings:
echo: M301 P22.20 I1.08 D114.00 C100.00 L20
echo:Filament settings: Disabled
echo: M200 D3.00
echo: M200 D0
Error:MINTEMP triggered, system stopped! Heater_ID: 0
[ERROR] Error:MINTEMP triggered, system stopped! Heater_ID: 0
Errortongue sticking out smileyrinter halted. kill() called!
[ERROR] Errortongue sticking out smileyrinter halted. kill() called!
Edited 1 time(s). Last edit at 07/25/2016 11:00PM by othoap.
Re: No LED Flashing
July 25, 2016 11:03PM
you have to fix the "Error:MINTEMP triggered"
all movement is suspended until that is fixed
This is the controller not able to read the thermistor on the hotend. This is normally a open circuit on the thermistor cable somewhere
This is a safety feature... you have to have the thermistor plugged in.
Edited 2 time(s). Last edit at 07/25/2016 11:06PM by Dust.
Re: No LED Flashing
July 26, 2016 05:21PM
Dust
thanks, that did it. I'm now talking to the ramps. Side note "nebbian" I could not get repetier to work but pronter did, thanks. I so many people run tests with only just one stepper hooked up and nothing else. I hooked up everything but the power to the hotend and bed and then it worked. I still don't see the two LED TX and Rx flicker but it works.
Re: No LED Flashing
July 29, 2016 11:35AM
Jean,
What's your setup? Is this a new build, a repair? The best I can offer is try a new thermistor or swap the hotend with the bed thermistor.
Re: No LED Flashing
July 29, 2016 08:31PM
You can continue to use Repetier with Marlin on RAMPS 1.4, if it isn't working something is not configured right. I have been using Repetier with Marlin 0.9 and 1.1.0 RCx for the last year with not a single problem. It is great software, the only reason I don't use it anymore is because I now use Replicape.
Edited 1 time(s). Last edit at 07/29/2016 08:32PM by zerodameaon.
