Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 05:16PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 05:21PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 05:24PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 05:34PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 05:43PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 06:18PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 06:55PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 07:13PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 21, 2016 08:23PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 22, 2016 09:30AM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 22, 2016 03:40PM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 23, 2016 07:13AM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 23, 2016 08:36AM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 23, 2016 08:55AM |
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 23, 2016 09:18AM |
MrBaz
DjDemonD
I do like petg and its very strong, but it doesn't produce such sharp objects as ABS and it oozes all over the place, so its swings and roundabouts.
Then you have something not calibrated correctly. I get sharp corners just fine.
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 23, 2016 09:26AM |
Vuokko
If you get too much adhesion on aluminium plate heat cycle it. If the part doesn't separate when the plate cools off, I usually heat it up to 60 degrees for a 15 minutes. Then I rapidly cool it down. I have 800g old CPU cooler in freezer to drop the temperature fast. usually I hear the part detaching quite fast with this trick.
Re: Chunks of glass stuck to heated bed. TOO MUCH BED ADHESION!! July 23, 2016 12:09PM |
