programm the dispenser and extruder
Posted by Tinkusharma
July 28, 2016 11:05AM
hello,
I am doing the 3d printer prusa mendal i2. I want to incorporate a solder paste dispenser unit to this, this dispenser unit will have the another motor and no heater or sensor [www.diyouware.com]. I want to know how to program these with marlin and currently I am using the Arduino mega 2560.so I want to know how to program it with the marlin.
thanks
VDX
Re: programm the dispenser and extruder
July 28, 2016 05:27PM
... it's nearly no difference between an extruder and motor-driven dispenser - you only have to deactivate all temperature reading/feedback and adjust the E0-steps accordingly for your dispensing nozzle diameter (volume per steps).
Have you found the associated sub-forum? - [forums.reprap.org]
Viktor
August 01, 2016 05:17AM
Thank you very much for your response but when i am trying to select the extruder as number 2 and on compiling its shows me error for the temp sensor. So could you please give me any programmed file for the 3d printer.
VDX
August 01, 2016 05:23AM
... you have to set the min-temps to 0 in the firmware or plug a dummy-resistor on the thermistor pins, so the measured "temperature" without thermistor will stay in the allowed range ...
Viktor
August 01, 2016 07:31AM
hello,
i am trying to set it but it say it needs an temp sensor.
exit status 1
#error TEMP_SENSOR_1 is required with 2 or more EXTRUDERS.
even i set up another temp sensor to it. please give me any suggestions and if you have the same type of file please forward it to me.
thank you very much for the help.
August 01, 2016 09:25AM
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Configuration_adv.h:689:0,
from sketch\Configuration.h:1129,
from C:\Users\Rinku\Desktop\Marlin-RC\Marlin\Marlin.ino:37:
SanityCheck.h:437: error: #error HEATER_1_PIN not defined for this board.
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
VDX
August 01, 2016 05:46PM
... read through the comments in the files "configuration.h" and "pins.h" - you have to set and define all the needed pins and numbers ...
Viktor
