RepRapFirmware currently runs on the Duet WiFi (ATSAM4E8E processor), Duet (ATSAM3X8E processor), and on Arduino Due + RADDS (also ATSAM3X8E processor). The sources of my fork (which is the official version for the Duet WiFi) are at [
github.com] for the main firmware and [
github.com] for the hardware abstraction layer.
Bear in mind that although the Pine64 provides the processor, USB interface, WiFi interface and SD card socket, to create a 3D printer controller similar to the Duet WiFi you would need to add the TMC2660 drivers, the mosfets and their drivers for the heaters and the fan, and ADC channels to do the temperature and supply voltage monitoring. Also it needs separate SPI channels for the stepper driver control and for accessories, so that slow accessories don't hold up commands to the stepper drivers.
Edited 1 time(s). Last edit at 08/01/2016 06:43PM by dc42.
