Anonymous User
Re: Small, light, effective fan shrouds for popular hotend designs April 29, 2017 10:34AM |
Re: Small, light, effective fan shrouds for popular hotend designs April 29, 2017 12:02PM |
Re: Small, light, effective fan shrouds for popular hotend designs April 29, 2017 12:16PM |
Re: Small, light, effective fan shrouds for popular hotend designs April 29, 2017 03:09PM |
Re: Small, light, effective fan shrouds for popular hotend designs April 29, 2017 03:33PM |
Re: Small, light, effective fan shrouds for popular hotend designs May 01, 2017 11:14AM |
cwaa
I have only been printing for about 1 1/2 years, but still haven't used a cooling fan. Why do you use them?
Re: Small, light, effective fan shrouds for popular hotend designs May 02, 2017 09:17AM |
Re: Small, light, effective fan shrouds for popular hotend designs May 02, 2017 11:14AM |
Re: Small, light, effective fan shrouds for popular hotend designs May 02, 2017 11:19AM |
Re: Small, light, effective fan shrouds for popular hotend designs May 13, 2017 11:54AM |
Re: Small, light, effective fan shrouds for popular hotend designs May 13, 2017 04:45PM |
Re: Small, light, effective fan shrouds for popular hotend designs May 14, 2017 05:39PM |
shortyski13
Do you think the cooling scheme in this design will work well, or do you think 2 fans on either side is really needed? (Pictures attached). Essentially, I upgraded the 30mm fan on the V6 hotend heatsink to 40mm and ducted it, just to give that some extra cooling and help prevent creep at higher temperatures, and then used the stock 30mm fan that comes with the hotend to blow fan on 2 sides of the nozzle/filament via ducts. The idea was to save a couple bucks (please don't argue this point of it, as it isn't the point of the question) and not have to buy 2 blower fans. Also, while it is a bit bulkier, due to the design of my printer, it actually does not take away from my print area.
[attachment 94115 Hotend_Cooling.PNG][attachment 94116 Hotend_Cooling2.PNG]
Re: Small, light, effective fan shrouds for popular hotend designs May 14, 2017 10:47PM |
Origamib
I've given up on fans for now.... I never found a decent solution other then a 50mm blower fan. Anything smaller seems awfully designed, or ridiculously expensive. The 40x10mm fans I hooked up are good, but they still add considerable bulk to the hotend that I'm not happy with. The design of the fan is such though that they have a lot of backflow and I wonder if they even push as much air as advertised. I may give one of these air pumps a try still.......
Re: Small, light, effective fan shrouds for popular hotend designs May 15, 2017 08:31AM |
shortyski13
Re: Small, light, effective fan shrouds for popular hotend designs May 15, 2017 08:33AM |
Re: Small, light, effective fan shrouds for popular hotend designs May 15, 2017 11:39AM |
Re: Small, light, effective fan shrouds for popular hotend designs May 15, 2017 12:05PM |
Re: Small, light, effective fan shrouds for popular hotend designs May 15, 2017 12:09PM |
Re: Small, light, effective fan shrouds for popular hotend designs May 16, 2017 07:54PM |
Re: Small, light, effective fan shrouds for popular hotend designs May 17, 2017 12:53AM |
drmaestro
What happens if you give 12 volts to a 5 volts fan? Does it start rotating 2 times faster?
Re: Small, light, effective fan shrouds for popular hotend designs May 17, 2017 04:58AM |
drmaestro
I also have this issue and I am trying to find a suitable compact solution for cooling. My current design uses rails and they tend to collide with the part cooling fan with the existing designs where the fan is tilted upwards. It seems I require a blower fan solution which can have a direct downwards output. I ordered a couple from Aliexpress but the seller cancelled them and told me they were too old to be sent, so not brand new. They were the only 30 mm ones working at 12 volts, the others generally work at 5 volts. Where do you source your blower fans from? What happens if you give 12 volts to a 5 volts fan? Does it start rotating 2 times faster? DjDemonD, I might go for your Sunons if you are happy with them (I also want to try your piezo solution, so maybe both of them can be handled in the same shipping?
Re: Small, light, effective fan shrouds for popular hotend designs July 31, 2017 10:54PM |
Re: Small, light, effective fan shrouds for popular hotend designs August 06, 2017 03:06AM |
Re: Small, light, effective fan shrouds for popular hotend designs October 29, 2017 02:34PM |
Re: Small, light, effective fan shrouds for popular hotend designs October 30, 2017 09:45AM |
Re: Small, light, effective fan shrouds for popular hotend designs October 30, 2017 10:28AM |
Re: Small, light, effective fan shrouds for popular hotend designs November 04, 2017 08:43AM |
Re: Small, light, effective fan shrouds for popular hotend designs November 04, 2017 04:04PM |
Re: Small, light, effective fan shrouds for popular hotend designs November 04, 2017 04:39PM |
Re: Small, light, effective fan shrouds for popular hotend designs November 08, 2017 10:51AM |
