Power Supply not starting?
August 20, 2016 11:01AM
I finally have the dual extruder assembled, and ready to go, I think.
I plugged it in to the 110 outlet, with switch set to 110. Plugged the usb into the computer,
Nothing has booted, Nothing on the power supply, and nothing has popped up under devices in window 8.1
Any advice?
Regards
Steven
Re: Power Supply not starting?
August 20, 2016 11:57AM
Lots more details required
What type of power supply? ATX type or LED type?
How is the power supply set to turn on? via the controller or on all the time?
What type of reprap controller?
Has this ever worked? ie was this an upgrade to dual extruder from a working single extruder machine?
Edited 1 time(s). Last edit at 08/20/2016 11:57AM by Dust.
August 20, 2016 01:32PM
Thank you for your response.
Here is a photo of the power supply. No documentation, not sure the type.
It is a dual extruder kit, not an upgrade.
I have just assembled the unit, it is the first time getting things started.
I am not sure which controller board, but I have attached a photo.
I pushed the little reset button on the side of the controller card, with no results.
ThanX again for your help
Regards
Steven
open | download - IMG_0542.jpg (161.3 KB)
open | download - IMG_0540.jpg (141.9 KB)
open | download - IMG_0541.jpg (162.7 KB)
August 20, 2016 01:41PM
Something doesn't look right in the second photo - could you take a close-up photo of your power supply wiring?
August 20, 2016 02:25PM
ThanX
would the power supply not have the fan on or an led light, when plugged in?
open | download - IMG_0543.jpg (146.5 KB)
August 20, 2016 03:19PM
I just unhooked all the wires from the power supply. But the power.
and the led light came on.
August 20, 2016 03:28PM
Hooked up the first red and black wire. post 1 and 4. Led did not come up.
then hooked the 2nd red and black. to post 2 and 5. Led light was on.
August 20, 2016 03:38PM
Extruder Heaters were both hot.
Heating bed was not.
when post 2+ was and 5- were hooked to the power supply.
August 20, 2016 04:02PM
I have now, hooked up post 3 and 6 with the sensor and fan leeds.
The Led light for the power supply is still going on.
Then I re connected the red on post 1 and black on post 4.
No Led on the power supply.
The problem, maybe the connections that power 1 and 4 post drive.
What next? To Check
August 20, 2016 05:13PM
Just when I thought this was the problem.
The 2 wires from the heating plate, going into the blue terminal. I re hooked them up, one side of the terminal plastic is crushed, a bit.
However, I think the connections are good.
But when I connect 1 red and 4 black post to the power supply. The LED on the power supply is still not lighting up.
open | download - IMG_0544.jpg (147.7 KB)
August 20, 2016 05:22PM
In Summary,
Heating extruders are hot.
Heating plate is not getting hot.
With power supply hooked up to post 2+ and 5-.
When I hook up 1+ and 4-.
The LED on the power supply is not on.
TaDA
Any advice?
August 20, 2016 10:05PM
where does the wires "1+ and 4-" on the supply go to?
I suspect they go to power pins 3 and 4 on the Green plug. This would be the power for the heated bed.
What you have is known a a LED power supply, it should always be on when mains is applied, unless there is a short.
Your controller is a ramps
Please take a photo of the heated bed (top view with any connection information) and secondly a photo of how the wires are connected to the heated bed.
August 22, 2016 10:10AM
Good Morning,
Yes 1+ and 4- go to 3 and 4 on the board.
I took the wires off the blue terminal, going to the heating bed.
Then attached 1+ and 4-, and still no LED on.
The short lies in the boards? The blue terminal on the plus side was damage a bit when first attaching the wire. HHUUMM.
Picture showing the wires attached to the bed from the blue terminal.
Can the bed be directly connected to the power supply?
Thank you for your help Mistro.
August 22, 2016 05:53PM
Yes you can power the heated bed board directly by plugging it into the power supply normally. It will just heat up uncontrollably, so don't leave it like this.
August 24, 2016 10:04PM
with the power supply off and the arduino plugged in via usb does it work?
