Re: Extruding Nylon May 25, 2011 05:19AM |
Re: Extruding Nylon May 25, 2011 06:57AM |
Re: Extruding Nylon May 25, 2011 07:14AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Extruding Nylon May 27, 2011 04:02PM |
Re: Extruding Nylon May 27, 2011 05:56PM |
Re: Extruding Nylon March 07, 2012 02:34PM |
Re: Extruding Nylon March 07, 2012 04:04PM |
Re: Extruding Nylon June 07, 2012 06:25PM |
Re: Extruding Nylon June 07, 2012 07:26PM |
Re: Extruding Nylon June 09, 2012 02:08AM |
Re: Extruding Nylon June 10, 2012 11:25AM |
Re: Extruding Nylon July 24, 2012 02:02AM |
Re: Extruding Nylon July 24, 2012 05:22AM |
Re: Extruding Nylon July 24, 2012 07:40PM |
Re: Extruding Nylon July 24, 2012 08:02PM |
Re: Extruding Nylon July 24, 2012 10:27PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: Extruding Nylon July 24, 2012 10:33PM |
Re: Extruding Nylon July 24, 2012 10:37PM |
Re: Extruding Nylon July 24, 2012 10:43PM |
Re: Extruding Nylon July 25, 2012 12:45AM |
Re: Extruding Nylon July 25, 2012 01:45AM |
Re: Extruding Nylon August 01, 2012 01:17AM |
. What I did is put a square of sheet metal over my heated bed, then I used the "brim" setting in slic3r with 15 loops. I then placed small magnets all around the "brim" after the first layer finished. This keeps the part nice and flat, with no warping evident, even with large parts
. Now I just need to work out the oozing problem. On long travels, the ooze makes a big difference, and makes a bunch of nasty globs all over the side of the part. I have my travel speed set at 600 mm/s, so that the nozzle will ooze less while traveling, and I have a retract of 1 mm. If I turn up the retract, the nozzle stays in the same spot for too long and creates a blob. Is there a way to make the extruder retract while it is traveling? I am using pronterface with slic3r.
Re: Extruding Nylon August 18, 2012 05:06AM |
Re: Extruding Nylon August 18, 2012 05:48AM |
Re: Extruding Nylon August 19, 2012 04:45PM |
Re: Extruding Nylon August 23, 2012 03:17AM |
Re: Extruding Nylon August 23, 2012 04:54AM |
Re: Extruding Nylon August 23, 2012 05:06AM |
Re: Extruding Nylon August 23, 2012 10:34PM |
Re: Extruding Nylon August 23, 2012 11:22PM |
