Most used / easiest way to print abs September 04, 2016 02:22PM |
Re: Most used / easiest way to print abs September 04, 2016 04:32PM |
Re: Most used / easiest way to print abs September 04, 2016 11:12PM |
Re: Most used / easiest way to print abs September 05, 2016 02:45AM |
Re: Most used / easiest way to print abs September 05, 2016 09:02AM |
Re: Most used / easiest way to print abs September 06, 2016 10:11AM |
Re: Most used / easiest way to print abs September 06, 2016 05:08PM |
Re: Most used / easiest way to print abs September 07, 2016 07:16AM |
Re: Most used / easiest way to print abs September 07, 2016 02:07PM |
Re: Most used / easiest way to print abs September 07, 2016 02:10PM |
Re: Most used / easiest way to print abs September 07, 2016 11:26PM |
Re: Most used / easiest way to print abs September 09, 2016 05:19AM |
Re: Most used / easiest way to print abs September 09, 2016 08:01AM |
Re: Most used / easiest way to print abs September 09, 2016 08:31AM |
Re: Most used / easiest way to print abs September 09, 2016 10:44AM |
Re: Most used / easiest way to print abs September 09, 2016 11:10AM |
Re: Most used / easiest way to print abs September 09, 2016 02:16PM |
Re: Most used / easiest way to print abs September 09, 2016 02:28PM |
Re: Most used / easiest way to print abs September 09, 2016 02:42PM |
Make sure to calibrate the nozzle distance when the whole machine including heatbed and nozzle is heated up to working temperature.Quote
Reacher
Was finally able to get my first printed item. For sure quality sucks. But it's a start.
For what I'm seeing my problem with the first layer is that the bed come a lot closer to the nozzle when things eat up.
Guess I'm gonna need to learn how to do this baby step thing.
Re: Most used / easiest way to print abs September 09, 2016 05:03PM |
Re: Most used / easiest way to print abs September 09, 2016 10:17PM |
Re: Most used / easiest way to print abs September 10, 2016 02:24PM |
;--- Prime --- G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion G28 ; home G1 X85.531 Y-183.2 Z0.320 F15000 ; Move to first prime pos G1 E6.7 F5700 ; Unretract G1 X28.510 Y-183.2 E6.792 F840 ; Prime 1 - going left Very Slow - 14mms G1 X-28.51 Y-183.2 E3.308 F1680 ; Prime 2 - going left Faster - 28mms G1 X-85.53 Y-183.2 E2.843 F1938 ; Prime 3 Fastest - 32mms G1 E-6.7 F7800 ; retract (this saves the pressure while the move is happening) G1 X-145.397 Y53.065 Z0.350 F6000 ; Move to first perimeter point G1 E8.1217 F5700 ; Unretract + 1.42mm pressure compensation ; (first perimeter)
Re: Most used / easiest way to print abs September 13, 2016 04:33AM |
Re: Most used / easiest way to print abs September 13, 2016 05:54AM |
Re: Most used / easiest way to print abs September 14, 2016 10:01AM |
Re: Most used / easiest way to print abs October 05, 2016 05:42AM |
