Re: An alternative to buying a bad kit for $300-500 October 24, 2016 07:41AM |
Re: An alternative to buying a bad kit for $300-500 October 24, 2016 08:45AM |
Re: An alternative to buying a bad kit for $300-500 October 24, 2016 10:34AM |
the_digital_dentist
I ran a multipart print last night to see see how well the glue works- it does. Soaking the plate in cold water for a few minutes released the parts. The print came out OK except for some overextrusion that I expected (I haven't calibrated it yet) and some slight shifting in the Y axis when the extruder moved from part to part (50 mm/sec vs 40 mm/sec print speed). Acceleration is down to 500 mm/s/s, so I'm going to play with the Y axis motor current a little and see if I can fix it that way before reducing acceleration/junction deviation further. I'll calibrate the extruder today, too.
Re: An alternative to buying a bad kit for $300-500 October 24, 2016 11:03AM |
Re: An alternative to buying a bad kit for $300-500 October 24, 2016 12:03PM |
TheJones
Dancook
I don't plan to use the original extruders, but I honestly can't see a reason to keep them... I was trying to find a way to use them as bowens.
Why not just clamp a bowden fitting where the hotend used to go? Seems pretty straightforward to me.
the_digital_dentist
As you can tell, I like reusing the existing cables as much as possible.
Are you planing on using the stock hotend wires? They seem a little thin to me, and I'm contemplating replacing them. Thought, to be fair, they could be fine and I might just be paranoid from my recent experience with my heated bed wiring.
Re: An alternative to buying a bad kit for $300-500 October 24, 2016 01:13PM |
Re: An alternative to buying a bad kit for $300-500 October 25, 2016 10:13AM |
Re: An alternative to buying a bad kit for $300-500 October 25, 2016 10:25AM |
Re: An alternative to buying a bad kit for $300-500 October 25, 2016 03:00PM |
Re: An alternative to buying a bad kit for $300-500 October 27, 2016 05:57AM |
Re: An alternative to buying a bad kit for $300-500 October 27, 2016 08:21AM |
Re: An alternative to buying a bad kit for $300-500 October 27, 2016 02:18PM |
TheJones
So, I modified my E3D heatsinks to fit the CubeX. I basically hacked off the top of the stock heatsink and used some brazing rod to attach it to the top of the E3D. I did the whole thing using really basic tools. Here are some pictures (brace yourself, it's basically a full write-up).
Re: An alternative to buying a bad kit for $300-500 October 27, 2016 04:21PM |
Kasahabo
I have been following this thread with great interest and am wanting to follow your examples. I do have a question. The Cube X Duo isn't always available but I do sometimes see the Cube Pro Duo. The lower prices are in line with what you are paying for the Cube X. Do any of you know the difference between the two? Would I have to re invent what has already been accomplished here?. I have tried to do some research but have not found the answers I am looking for other than the following. The printing environment is enclosed and the printing area looks to be a little greater with the Pro.
Thanks for you help.
Dancook
TheJones
Excellent job on those hot ends, TheJones!
Re: An alternative to buying a bad kit for $300-500 October 27, 2016 06:38PM |
Re: An alternative to buying a bad kit for $300-500 October 27, 2016 09:26PM |
Re: An alternative to buying a bad kit for $300-500 October 27, 2016 11:50PM |
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 02:08AM |
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 04:58PM |
the_digital_dentist
Looks great, but what is the purpose of the Bowden tube connector at the input to the extruder?
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 08:01PM |
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 08:17PM |
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 09:08PM |
TheJones
More progress this evening. I'm working on the wiring right now, which will likely be temporary until I get my upper enclosure built.
Here is my solution for the z limit switch. I re-purposed a piece of acrylic that I had stripped off earlier, and used the waste bin height adjuster as a set screw.
It seems pretty solid. It will probably stay like this until I replace that back plate, them I'll make something similar from some scrap aluminum.
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 09:09PM |
Dancook
I'm having a lot of issues with this Replicape controller in my printer... there's not much support for it, so it was probably a bad idea for my first attempt at building my own. I wish I would have gotten a smoothieboard instead.
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 09:15PM |
the_digital_dentist
I think you'll get better repeatability if you remove the lever from the microswitch.
the_digital_dentist
I'm going to try using the scraper and waste bin- I have found that the nozzles tend to accumulate a lot of crud due to the shallow profile. If you use dual extrusion the scraper can be used in lieu of a tower to prime and clean the nozzle on tool-change. Just move the extruder past the scraper, extrude a few mm of filament, and drag the nozzle back over the scraper to knock it off. I don't know if that will work if you changed to E3D hot-ends. The profile of the nozzles may be too steep to use the scraper.
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 09:16PM |
TheJones
Dancook
But assuming that you are going to keep the Replicape, what issues are you having with it?
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 09:31PM |
Dancook
I'm having trouble configuring the stepper directions and endstops... trying to figure out M code and G code...
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 10:29PM |
TheJones
Sorry I can't help more, I've never used Redeem. About the best thing I can tell you is to start watching every YouTube video you can on the subject. Your first searches might not show the video you need, but after a few videos you will start seeing related videos in your "recommended" section. You'd be surprised what you can stumble on that way
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 10:42PM |
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 11:02PM |
Re: An alternative to buying a bad kit for $300-500 October 28, 2016 11:05PM |
Re: An alternative to buying a bad kit for $300-500 October 29, 2016 03:00AM |
Dancook
