Re: An alternative to buying a bad kit for $300-500 December 11, 2016 09:10AM |
Re: An alternative to buying a bad kit for $300-500 December 11, 2016 10:08AM |
Re: An alternative to buying a bad kit for $300-500 December 11, 2016 12:07PM |
Re: An alternative to buying a bad kit for $300-500 December 11, 2016 01:51PM |
the_digital_dentist
As much as I prefer to print from SD cards, this machine will probably remain connected to a netbook computer (running linux) that hasn't had anything better to do for a couple years, mainly because I don't want to rewire the entire machine so I can move the controller board to the front of the machine where I would mount the LCD.
the_digital_dentist
I noticed that the heatsink in the hot-end because quite warm while it was printing. I think that mounting the cooling fans directly on the hot-end like the E3D approach would keep them a lot cooler and maybe prevent some jams with PLA.
Re: An alternative to buying a bad kit for $300-500 December 11, 2016 02:03PM |
dc42
the_digital_dentist
Where did they put the hot end cooling fan then, if it wasn't either on the hot end, or on the print head and ducted to the hot end heatsink?
Re: An alternative to buying a bad kit for $300-500 December 11, 2016 08:11PM |
Re: An alternative to buying a bad kit for $300-500 December 11, 2016 08:14PM |
obelisk79
... Would you be interested in the STL's for the CoreXY conversion I'm doing to my CubeX? They aren't complete yet so I won't post them until I have proven that they function on my own frame first but I'm more than happy to share with anyone interested.
Re: An alternative to buying a bad kit for $300-500 December 12, 2016 05:32PM |
the_digital_dentist
The controller talks to the LCD/SD card via SPI. Cables have to be short or communications fail due to loss of sync. If you want the LCD up front, you have to put the controller close to the front of the machine, and that means rewiring everything because the original controller was located near the back corner of the printer.
Re: An alternative to buying a bad kit for $300-500 December 14, 2016 12:44AM |
Re: An alternative to buying a bad kit for $300-500 December 14, 2016 08:54AM |
Re: An alternative to buying a bad kit for $300-500 December 14, 2016 02:43PM |
the_digital_dentist
dc42: I'll see if I can locate a longer ribbon with the heavier gauge wires to try it. We probably have something like that at the makerspace. I've never actually tested the limits of the spi cable, just stuck to the cables that came with it, which IRIC are about 300 mm long. I will need about maybe 450 mm to reach the front of the machine if I leave the controller board in the back corner where the original was.
advancedrescue: 12V or 24V heater depends on your power supply voltage. If you use the original 15V supply, get a 12V heater. If you are switching to 24V, get a 24V heater (though you can make a 12V heater work on 24V by limiting PWM to 64). You can't make a 24V heater work on a 12 or 15V power supply.
Re: An alternative to buying a bad kit for $300-500 December 14, 2016 07:18PM |
Re: An alternative to buying a bad kit for $300-500 December 14, 2016 08:23PM |
Re: An alternative to buying a bad kit for $300-500 December 14, 2016 09:14PM |
Re: An alternative to buying a bad kit for $300-500 December 14, 2016 11:08PM |
Re: An alternative to buying a bad kit for $300-500 December 15, 2016 07:50AM |
the_digital_dentist
I've been using DesignSpark Mechanical, but starting to learn Fusion 360 because it has CAM capabilities built in which means I can use it to run the Tormach mill, the CNC router, and CNC plasma cutter at the makerspace.
Re: An alternative to buying a bad kit for $300-500 December 15, 2016 07:52AM |
Re: An alternative to buying a bad kit for $300-500 December 15, 2016 08:38AM |
advancedrescue
Anyone want to send me their cubex filament cartridges? Even if empty
Re: An alternative to buying a bad kit for $300-500 December 21, 2016 12:14PM |
Re: An alternative to buying a bad kit for $300-500 December 21, 2016 12:47PM |
Re: An alternative to buying a bad kit for $300-500 December 21, 2016 01:00PM |
Re: An alternative to buying a bad kit for $300-500 December 21, 2016 01:36PM |
Re: An alternative to buying a bad kit for $300-500 December 21, 2016 02:12PM |
Re: An alternative to buying a bad kit for $300-500 December 21, 2016 04:08PM |
Re: An alternative to buying a bad kit for $300-500 December 22, 2016 09:53AM |
Re: An alternative to buying a bad kit for $300-500 December 22, 2016 09:58AM |
Re: An alternative to buying a bad kit for $300-500 December 22, 2016 11:33AM |
Re: An alternative to buying a bad kit for $300-500 December 22, 2016 11:51AM |
Re: An alternative to buying a bad kit for $300-500 December 22, 2016 11:26PM |
Re: An alternative to buying a bad kit for $300-500 December 23, 2016 07:32AM |
