Re: An alternative to buying a bad kit for $300-500 January 22, 2017 06:15AM |
Re: An alternative to buying a bad kit for $300-500 January 22, 2017 07:27AM |
Re: An alternative to buying a bad kit for $300-500 January 22, 2017 07:40AM |
the_digital_dentist
Interesting... Are you aware that a lot of people have problems with the graphic LCD overloading the 5V regulator on the RAMPS board? Why autoleveling? Autoleveling is great for machines that can't maintain the bed leveling, but these Cubex machines are stable and don't require releveling once they are set up (at least mine hasn't).
Re: An alternative to buying a bad kit for $300-500 January 23, 2017 06:50PM |
Re: An alternative to buying a bad kit for $300-500 January 24, 2017 05:21AM |
Re: An alternative to buying a bad kit for $300-500 January 24, 2017 08:02AM |
bolsoncerrado
Just in case any Cube3/Pro owners read this thread, the firmwares have been hacked to allow third party filament
[www.print3dforum.com]!!!
Re: An alternative to buying a bad kit for $300-500 January 24, 2017 08:24AM |
Re: An alternative to buying a bad kit for $300-500 January 24, 2017 08:31AM |
Re: An alternative to buying a bad kit for $300-500 January 24, 2017 09:19AM |
Re: An alternative to buying a bad kit for $300-500 January 24, 2017 10:26PM |
Re: An alternative to buying a bad kit for $300-500 January 27, 2017 08:35AM |
the_digital_dentist
Re: An alternative to buying a bad kit for $300-500 January 27, 2017 08:53AM |
DaGameFace
Anyone try to remove the X axis yet? Ideally I would like to remove a ton of weight from it but not sure that I can take the smooth rods of the X axis out of the blocks that are the Y axis without tearing down the whole printer.
Re: An alternative to buying a bad kit for $300-500 January 27, 2017 09:30AM |
Dancook
My Duo has been very fickle lately about the bed leveling... not sure why... one print, it's fine, the next, I'll get the dreaded extruder clicking because the bed is too high. Maybe it's the crazy weather and my (probably too thick) cork bed?
I ordered these for the Kossel I'm building: [www.ultibots.com]
I'm excited to get it built... maybe I'll retire the Duo...
Re: An alternative to buying a bad kit for $300-500 January 27, 2017 11:14AM |
fg dude
DaGameFace
I think you have no other choice than to remove one side of the printer completely.
Re: An alternative to buying a bad kit for $300-500 January 27, 2017 11:35AM |
the_digital_dentist
Dancook
Early on I found that the three, weird little rubber bumpers the bed sits on tend to lift themselves out of the bed support plate and cause the bed level to shift. Get rid of those things and replace them with almost anything that will stay put. I contact-cemented some rubber o-rings to the support plate, but almost anything will work. In fact, those little things aren't entirely necessary because the bed leveling is done by adjusting the bed support plate.
Re: An alternative to buying a bad kit for $300-500 February 03, 2017 10:38PM |
Re: An alternative to buying a bad kit for $300-500 March 01, 2017 05:43PM |
Dancook
Cubex is almost back together... currently printing corners for a Delta.
Re: An alternative to buying a bad kit for $300-500 March 01, 2017 05:53PM |
Re: An alternative to buying a bad kit for $300-500 March 05, 2017 03:35PM |
Re: An alternative to buying a bad kit for $300-500 March 06, 2017 03:50PM |
advancedrescue
Anyone have, or thought about adding a blower/ radial fans to to replace the 3 large print cooling fans? I was mainly interested in it as a possible way to clean up the carriage and give better view of the print area. The three fans that are there now are too powerful as it is (at least for me). I had to wrap my E3D volcanos with silicone in order for them not to send a fault to my duet wifi. It would detect a heating issue,and I could turn them on and i could actually see the temp of the heating block cooling while it was trying to heat. But that's all been solved due to the silicone wrap of the heating block.
On another note, got my printer pretty much done. Got a lot of mods done and the duet wifi pretty well dialed in. There's a few issues I need to work out though. In Simplify3d I try to set PWM fan 0 to turn on after the first layer(or any layer) and it doesn't. So I need to look into that more. Also my prints are mirrored. I printed something the other day with my wife's name on it. Instead of saying "WHITNEY" it said "YENTIHW" with the E and N also backwards. I'm guessing the X axis needs to be reversed.
Re: An alternative to buying a bad kit for $300-500 March 06, 2017 06:12PM |
Re: An alternative to buying a bad kit for $300-500 March 07, 2017 07:23AM |
advancedrescue
Right now I have mine setup to zero in back left. I got my y endstop in the back right, and x endstop on the left. So when homing it raises hitting the z endstop, then left to hit x endstop, then back to hit the y endstop. After zeroing out homing ithe extruder position is off the actual print bed. Then the extruders move forward to the back left corner of the bed, then via g code it sets that to the zero position
So if the proper position is front left instead of my back left, does that mean I need to flip the y and that correct my mirrored?
I have the mechanical endstops used and mounts from the cubepro. I can take pictures of it tomorrow when at the fire station when I'm on duty.
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 01:00AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 01:41AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 03:01AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 05:04AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 07:19AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 08:10AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 08:13AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 08:49AM |
