Re: An alternative to buying a bad kit for $300-500 March 10, 2017 09:09AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 09:14AM |
the_digital_dentist
I don't see any lines in the Z axis of prints made on my CubeX. I don't think it's the screw.
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 10:40AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 11:17AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 11:24AM |
Dancook
It happens in every print... I've sliced with three different slicers (Cura, Slic3r, S3D) with the same results... different resolutions... It has to be something physical with the printer... I also considered "heat banding" from the bed, but that kitten was printed without heat.
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 11:45AM |
Dancook
the_digital_dentist
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 11:57AM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 12:05PM |
Re: An alternative to buying a bad kit for $300-500 March 10, 2017 06:39PM |
Dancook
That happens with any print job, filament, multiple slicers, multiple temps, it's basically going to happen... so I'm thinking it's physical. My only other thought is maybe PIDs, since the hot end is the only other thing that's constant? But I'm thinking that's even a long shot. It's more of an under extrusion kind of like a missed step... I can pull prints apart some times. You can see the ear in the pic above looks more like a missed step. (It's not a missed step...)
Re: An alternative to buying a bad kit for $300-500 March 11, 2017 03:55PM |
Re: An alternative to buying a bad kit for $300-500 March 11, 2017 04:32PM |
Re: An alternative to buying a bad kit for $300-500 March 12, 2017 06:02AM |
Re: An alternative to buying a bad kit for $300-500 March 13, 2017 08:24AM |
advancedrescue
For the most part I'll probably use the printer out of the housing unles I start using it for ABS. It's in the housing now because I had to bring it home from the fire station. I probably won't have time to mess with it for awhile at home so for the time being I'll leave it in the housing to protect it.
Re: An alternative to buying a bad kit for $300-500 March 13, 2017 09:53PM |
Re: An alternative to buying a bad kit for $300-500 March 14, 2017 01:37PM |
Re: An alternative to buying a bad kit for $300-500 March 14, 2017 07:27PM |
advancedrescue
I've printed a lot with it and it prints great, but need to figure out why the layer fans don't come on. Has something to do with Simplify3d. I can type in M106 P0 in the duet web interface and they come on as they should, just can't get them to respond from S3D. Also got to figure out the mirrored print.
Re: An alternative to buying a bad kit for $300-500 March 15, 2017 01:03AM |
fg dude
sorry to heare that story, I hope you get along with the guy in the future and everyting gets ok again.
Re: An alternative to buying a bad kit for $300-500 March 15, 2017 07:50AM |
Re: An alternative to buying a bad kit for $300-500 March 15, 2017 05:10PM |
Re: An alternative to buying a bad kit for $300-500 March 19, 2017 03:50PM |
Re: An alternative to buying a bad kit for $300-500 March 19, 2017 06:11PM |
Re: An alternative to buying a bad kit for $300-500 March 20, 2017 07:30AM |
dc42
The "M106 S$" config you have in S3D should work. You don't need the P0 parameter because that is the default. S3D should output M106 S255 to turn the fan full on. There is no way that S3D should output M106 with no parameters at all, there should always be an S parameter included in the command.
Re: An alternative to buying a bad kit for $300-500 March 20, 2017 03:38PM |
Re: An alternative to buying a bad kit for $300-500 March 21, 2017 08:58AM |
Re: An alternative to buying a bad kit for $300-500 March 24, 2017 09:28PM |
Re: An alternative to buying a bad kit for $300-500 April 02, 2017 03:43AM |
Re: An alternative to buying a bad kit for $300-500 April 02, 2017 04:55AM |
KmanOz
Hi Guys
New to this printer. Just bought a Duo and have read this long thread multiple times. To be honest I am none the wiser as to which way to go. I would have thought by now that maybe someone would have redesigned (printed) a whole new print head assembly. To me it seems that may be the easiest thing to do but of course I may be wrong. That with a couple or 3 e3d v6 on a custom print head assembly would be ideal but correct me if I am wrong. Also I'd want to move the print bed itself into the center so all 3 heads had the same coverage and add a heater.
Has anyone documented any of the connectors and wiring harnesses anywhere. I guess I can trace all the wring back to the controller but clearly it's been done before many times.
I feel there will be more people finding considering you can pick up this printer for next to nothing.
Anyway hi and look forward to giving this a go.
Kman
Re: An alternative to buying a bad kit for $300-500 April 02, 2017 11:11AM |
KmanOz
Kman
Re: An alternative to buying a bad kit for $300-500 April 04, 2017 07:47AM |
Dancook
KmanOz
Kman
Kman,
I would suggest getting a new controller... we've documented several kinds in this forum... Smoothieboard, Duet, Replicape, etc... I'd certainly go with a 32 bit option.
Dan
Re: An alternative to buying a bad kit for $300-500 April 04, 2017 08:06AM |
