Re: An alternative to buying a bad kit for $300-500 April 04, 2017 08:21AM |
the_digital_dentist
The bed is shifted to one side to make room for 2 filament spools on one side of the machine (and one spool on the other side). It should be pretty easy to move the bed plate over on the existing platform, but if you're going to heat it you'll lose some Z volume because you'll have to stand the bed plate up off the support plate.
The extruders that come with the machine are not especially good- they seem to have a large heated volume that oozes filament constantly. I have almost given up on them and will be replacing them at some point soon. The way the extruder mount is designed, with the hot end located between the massive X axis bearings, makes it very hard to see what's going on at the extruder nozzle(s). I find that very frustrating.
Re: An alternative to buying a bad kit for $300-500 April 07, 2017 08:07PM |
Re: An alternative to buying a bad kit for $300-500 April 08, 2017 06:57AM |
jmar896
Would anyone be kind enough to share their firmware for their CubeX or CubePro? I have finally completed my build of my CubePro, but have been struggling tuning in things like the jerk. I would really appreciate it.
Re: An alternative to buying a bad kit for $300-500 April 22, 2017 11:26PM |
Re: An alternative to buying a bad kit for $300-500 April 23, 2017 05:00AM |
hisforhack
Hi to all I am new to this forum.
I am in the process of converting my CubePro Duo with a MKS Gen 1.4 control board, using the original power supply, hotends,etc... the 2-Y axis steppers motor are run in parallel using a single DRV 8825 stepper drivers. I am having issues with Y-axis miss steps on my prints. The Refer voltage on all the stepper drives are set a .8 volts, I am considering increasing the voltage on the Y- stepper driver to 1.2 volts. Any guidance with this problem would be welcome.
Cheers
Hisforhack
Re: An alternative to buying a bad kit for $300-500 April 24, 2017 07:13AM |
Re: An alternative to buying a bad kit for $300-500 April 24, 2017 07:14AM |
Re: An alternative to buying a bad kit for $300-500 April 25, 2017 11:41PM |
Re: An alternative to buying a bad kit for $300-500 April 26, 2017 07:09AM |
Re: An alternative to buying a bad kit for $300-500 April 26, 2017 09:06AM |
Re: An alternative to buying a bad kit for $300-500 May 12, 2017 10:43PM |
Re: An alternative to buying a bad kit for $300-500 May 13, 2017 05:39AM |
hisforhack
A quick update on the problem of the Y axis missed steps and shifting.(photo)
Now the problem is that I can only use one extruder. After some more testing I will be looking into upgrading to a "Rumba Board" so can set up the second extruded.
Thanks for all the suggest
Re: An alternative to buying a bad kit for $300-500 May 13, 2017 11:56AM |
Re: An alternative to buying a bad kit for $300-500 May 13, 2017 10:23PM |
Re: An alternative to buying a bad kit for $300-500 May 13, 2017 11:57PM |
Re: An alternative to buying a bad kit for $300-500 May 14, 2017 04:01AM |
Re: An alternative to buying a bad kit for $300-500 May 16, 2017 10:44AM |
Re: An alternative to buying a bad kit for $300-500 May 28, 2017 12:27PM |
Re: An alternative to buying a bad kit for $300-500 May 29, 2017 11:50AM |
Re: An alternative to buying a bad kit for $300-500 May 29, 2017 12:21PM |
Re: An alternative to buying a bad kit for $300-500 May 30, 2017 12:54PM |
Re: An alternative to buying a bad kit for $300-500 May 30, 2017 03:07PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2017 06:37PM |
hisforhack
Last night My Pi Cubepro was printing ABS very well at 35 mm/sec, 230c, heated build chamber at 55c. "NO heated bed". Problem now is, it prints the part as a mirror image in the X-Axis, I need to change firmware and stepper motor cable tomorrow. I have CubeX frame and slides for parts, how hard is it to change to a Core X-Y? have you done it?
Cheers
Derek
Re: An alternative to buying a bad kit for $300-500 June 08, 2017 06:40PM |
Re: An alternative to buying a bad kit for $300-500 August 27, 2017 11:57PM |
Re: An alternative to buying a bad kit for $300-500 August 28, 2017 04:06AM |
Re: An alternative to buying a bad kit for $300-500 February 16, 2018 04:12PM |
Re: An alternative to buying a bad kit for $300-500 February 16, 2018 04:27PM |
Re: An alternative to buying a bad kit for $300-500 February 16, 2018 06:44PM |
