Re: An alternative to buying a bad kit for $300-500 February 11, 2019 03:57AM |
Re: An alternative to buying a bad kit for $300-500 March 15, 2019 08:00PM |
Re: An alternative to buying a bad kit for $300-500 March 16, 2019 09:03AM |
Re: An alternative to buying a bad kit for $300-500 March 17, 2019 08:16PM |
Re: An alternative to buying a bad kit for $300-500 March 28, 2019 12:16PM |
Re: An alternative to buying a bad kit for $300-500 March 28, 2019 12:37PM |
Re: An alternative to buying a bad kit for $300-500 March 28, 2019 01:18PM |
Re: An alternative to buying a bad kit for $300-500 April 04, 2019 12:08PM |
Re: An alternative to buying a bad kit for $300-500 April 06, 2019 01:27PM |
Re: An alternative to buying a bad kit for $300-500 April 18, 2019 12:48PM |
Re: An alternative to buying a bad kit for $300-500 April 28, 2019 04:22PM |
Re: An alternative to buying a bad kit for $300-500 April 30, 2019 05:58PM |
Re: An alternative to buying a bad kit for $300-500 May 05, 2019 01:46PM |
Re: An alternative to buying a bad kit for $300-500 May 05, 2019 02:37PM |
monkey
Either way the clone seems to protrude enough with the super long threaded adapter, don't know how well that'll print.
Re: An alternative to buying a bad kit for $300-500 May 05, 2019 02:53PM |
GT500
Noticed the fans that are installed in the base blow up so maybe start there and add a couple small fans at 90 degrees to blow across the drivers.
Re: An alternative to buying a bad kit for $300-500 May 05, 2019 03:58PM |
jimboh3
I installed my Tango (mod of rumba) over the front of the two fans using a printed mount and pillars so that front fan is blowing on the underside of thePCB where the stepper drivers/ Mosfets are and I installed a new cover over the top with a raised lid for the hole over the rumba. so the back fan blows air onto the underside and is forced over the stepper heatsinks. I also added heatsinks to the large mosfets. I was going to print a air guid for the back fan that forces the air forward but have not gotten around to that yet.
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 02:43PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 03:09PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 06:26PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 06:35PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 06:46PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 07:28PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 08:04PM |
Re: An alternative to buying a bad kit for $300-500 June 08, 2019 11:00PM |
Re: An alternative to buying a bad kit for $300-500 June 09, 2019 04:21AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: An alternative to buying a bad kit for $300-500 June 09, 2019 05:02PM |
Re: An alternative to buying a bad kit for $300-500 June 09, 2019 08:07PM |
Re: An alternative to buying a bad kit for $300-500 June 10, 2019 01:43AM |
Ohmarinus
Today I found an XYZprinting Davinci printer for 75 euros. It appears to be in new condition. I'm not sure how good it is, but I believe it has either 10 or 12mm guide rods and an enclosure. I'm really thinking of getting one and REPRAP-ifying it
Anyone knows anything about these printers?
It looks like it's this one:
[www.xyzprinting.com]
Re: An alternative to buying a bad kit for $300-500 November 07, 2019 01:59AM |
Re: An alternative to buying a bad kit for $300-500 November 07, 2019 02:46AM |
