Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 04, 2016 04:05PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 04, 2016 04:25PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 04, 2016 04:49PM |
Simon0362
Ping.........!
Anybody advanced any further with this project?
I heavily modified the casing drawings to arrive at something suitable for my Kossel where the E3d hangs underneath the spider but a load of other diversions mean that I don't yet have a fully operational unit - but I am interested to hear how others are getting along.
Having recently moved house, my workshop is slowly getting back to being operational again (the 03D stuff sits in the office!), and this included a CNC mill and lathe which I intend to use to try some of the components in aluminium - especially the outer gear casing and probably the pin carrier and shaft. Update will follow when I get somewhere closer!
Regards,
Simon
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 04, 2016 04:56PM |
dc42
Looks good! Two questions:
1. The BOM says to use the 3mm direct drive variant of the E3D. Can I build a 1.75mm version instead?
2. What is the reason for using a 0.9deg motor? With 16:1 gearing I would have thought 1.8 deg would be adequate.
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 04, 2016 05:14PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 04, 2016 08:01PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 17, 2016 06:34AM |
frankvdh
Any thoughts on driving this via cable rather than directly by the stepper motor?
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 17, 2016 07:02AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 17, 2016 01:13PM |
Genie
Hi powdermetal,
Recently, I'd read the previous thread and strongly interested in your design. Then I asked my friends to join for group buying of NEMA 14 pancake stepper to replicate the experiment. Now we share a couple of steppers each among three guys, and another one is going to buy himself. Parts on BOM are already in the hands. Slowly starting, I hope it will go well.
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 18, 2016 04:31AM |
powdermetal
If you go for machined components, pls include the two eccentric gears as well in Aluminium - their profile's precision and holes' pitch angles are crucial for a uniform transmission. Waiting for my Aluminium parts as well - would whish, I had your equipment...
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 18, 2016 02:55PM |
Simon0362
Hi PM - good idea to move and refocus the discussions.
These 3 screenshots show my own adaptation of your mount as described in my 'ping' - BTW, I converted this for 1.7mm instead of 3mm since that is all I use
The intention is that this sits above the spider and the E3D sits underneath with long screws clamping the two parts with the spider in the middle. The setting on my Kossel allow enough room (I hope!) to fit between a pair of arms and not to foul....famous last words of course but the trial runs seem to be ok.
Do you have dxf's of the case and the 2 gears? I can re-draw and convert but I am aware of the potential loss of accuracy each time I move from one CAD to the next...
No hurry, the mill is still idle on the bench awaiting some parts and me to reconnect everything in sight - but this will be a priority run...
Simon
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 19, 2016 01:12AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 20, 2016 03:26PM |
o_lampe
I was wondering if the outer gear shape has to be milled or could it be build with a plain backplate and dowel pins?
The free ends of the pins would then be pressed in the extruder gear housing.
Such an open design would allow watching the cycloid do it's job, too
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 20, 2016 05:39PM |
Simon,
the machining looks promising!
Coming back to the previous post: How does the assembly look like on your spider?
I am still not happy with the packaging: Hanging everything below the spider is fine for the center of mass and the motion direction of action, but reduces build-volume. Also it makes the nozzle more sensitive to any "wiggle" in the printer's actuation system.
Arranging things above the effector may cause interference between the motor and the arms and creates non-balanced forces due to the elevated center of mass. Maybe your design is a good compromise.
Do you still need the DXF's? If so, please let me know.
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 21, 2016 02:54AM |
Simon0362
Regarding the packaging - I think somewhere along the line I have failed to allow for some of the worst case scenarios so there is some interference - I need much more time to analyse this which I won't have through until sometime next week so my solution may still end up with more changes....I can see me trying to reduce the overall length from the front of the moter to the centreline as much as possible, so maybe yet thinner ball races for instance...
These are how it looks in a rough mockup state to give you an understanding of how I intended it - needs more thought and measurement on my part!
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 21, 2016 08:56AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 21, 2016 11:46AM |
o_lampe
This mockup above is still without stepper. I'm afraid it will interfere with the rods, as soon as they "go sideways"...
o_lampe
My earlier idea I shared with powdermetal was to split stepper and gearbox and put them on each side of the filament drive gear with an extended shaft on the stepper and a hollow shaft as gearbox output. That way the COG would be in the middle of the effector and the chance of interference with the rods would be lower.
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 22, 2016 05:31AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit October 23, 2016 02:57PM |
o_lampe
Of course one could build an effector where the hotend is mounted off center to give room for the recent in_line version.
o_lampe
When using a 90° bevel gear you could completely skip the cycloid gearbox, since there are many readymade bevel gears available from RC-car spares.
Probably adding new issues to feed the filament in a straight way, but worth thinking about.
Maybe a slim/long NEMA11 stepper, sitting parallel to the coldend heatsink, driving the 90° gears would make the smallest footprint and has a low COG.
Stepper and heatsink could both be cooled by one fan, nice!
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 02, 2016 03:06PM |
Simon0362
managed to get my CNC mill functioning at the weekend and the first run was the eccentric gears - the photos show two batches (the beauty of CNC to replicate!) along with the trial piece (failed to cut one pin hole!) and a couple of plastic printed pieces in a rather garish yellow...
Could have been easier if I had had some aluminium of the correct thickness instead of having to machine some 6.5mm down.
The next couple of pictures show the start of the machining of the gear casing itself - 2 copies again. This is the roughing out of the cycloidal path with a nice chunky 6mm tool, the detailed bit will be done with a petite and delicate 3mm version!
More to follow.......
Simon
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 03, 2016 04:03AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 04, 2016 04:36AM |
Simon, what thickness of aluminum did you use for the eccentric gears? Also, did you use the same tooling as the housing? Also do you happen to know the weight difference between the aluminum and printed parts?
I have access to a CNC mill and may have to give this a shot since I was having a hard time getting usable prints out of PETG.
Erich
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 04, 2016 03:18PM |
Kewtdz
Simon0362
Simon
Erich
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 05, 2016 02:36PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 05, 2016 03:36PM |
Kewtdz
Thank you all for the information! I'm not sure the extent of the tooling that my local makerspace has but I think much of it is imperial based. Since the parts were designed with a single cutter, I'll probably purchase the required tooling.
Also, o_lampe, I thought of using POM too and wondered if it would work well. After hearing your experience, I'll probably go that direction as I've worked with POM before and it is a wonderful material. I'll make sure to post here as I get things completed.
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 07, 2016 09:34AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 10, 2016 03:08PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 10, 2016 04:29PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 11, 2016 06:20AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 13, 2016 02:57PM |
asbo
Looking good powdermetal
Sorry I haven't posted the SolidWorks conversion I said I would, I got frustrated and gave up because I could never get the formula to work properly.
