Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 14, 2016 06:04AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 14, 2016 04:11PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 15, 2016 02:10AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 15, 2016 08:38AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit November 15, 2016 01:57PM |
o_lampe
My POM gears worked flawlessly until I changed the effector for some other extruders I'm testing ( E3D chimera & cyclops, diamond ) The cycloid drive is sitting on my "trophy shelf" waiting for another chance.
Funny how the Bowden setup in your test has the best seam. The 1.75 sample has some signs of ringing right from the seam and the 3mm sample has diameter/extrusion variations.
Recently I had a MK8 drive gear which wobbled badly, causing uneven extrusion. Maybe you see the same with the 3mm gear?
Kewtdz
The aluminum setup really looks amazing. Also, what are the tolerances you are shooting for to be considered precision?
Unfortunately, I haven't been able to work on it yet. I've been traveling this last week and I'm hoping to pick up the material this week/early next week.
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit December 05, 2016 02:42PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit December 05, 2016 04:47PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit December 06, 2016 07:31AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit December 06, 2016 09:56AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit December 06, 2016 10:08AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit December 08, 2016 10:07AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 06, 2017 05:20AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 06, 2017 05:42AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 06, 2017 10:20AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 06, 2017 11:18AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 06, 2017 02:13PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 09, 2017 03:14PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 10, 2017 02:48AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit February 11, 2017 01:24PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 29, 2018 05:25AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 29, 2018 05:42AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 29, 2018 05:54AM |
MKSA
It is a nice exercise but again, what are the advantages compared to two simple gears and do they offset the extra complexity, weight, cost, size,friction, backlash .... ?
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 30, 2018 02:54PM |
o_lampe
I suggested a different design for a 1:8 geared cycloid drive in the Smart Effector adapter thread, but want to discuss it here where it belongs.
As a newbie in fusion360 I failed to construct the inner gears, but the main things I wanted to point out are the 6mm bronce bushings on 4mm dowel pins.
There is only one tooth of either gear in full contact with the bushing, so I think one bushing per pin is enough.
Is it overkill or would it help to minimize friction?
PS: there are plenty of other bushing sizes available. Bronce and POM gears would work well, but POM bushings and aluminum gears, too.
MKSA
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 30, 2018 03:41PM |
powdermetal
MKSA
Well, ratios above 1:6 are getting hard to achieve with two simple gears - for the small gear a practical limit is approx.12 teeth as a minimum, so the second gear will become quite large. The same is true with planetary gearboxes.
Mechanical engineering has a broad range of solutions for speed reducers (some of them very well known, others less known) - depending on the application's needs, you will always find a solution.
Anyway, of course you are right: It is more complex than two simple gears.
Not so sure about the other criteria...
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 30, 2018 04:08PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 30, 2018 04:52PM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 30, 2018 05:12PM |
powdermetal
Cool! You found your solution!
What's the rated torque of your motor and what current are you running it and what type of hobgear do you use?
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 31, 2018 12:56AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 31, 2018 03:01AM |
Re: Cycloidal Extruder Drive: A lightweight direct extruder drive unit January 31, 2018 05:37AM |
o_lampe
[OT]
I would have gone for remote driven extruders too, but the stiffness of the cable was always a big questionmark. I thought of different solutions, like closed loop spectra line, but didn't find any.
Direct drive (geared ) extruders could be so much smaller with a smaller filament diameter. That's what I'm working on for my coffeemug Delta.
We've seen how much 3DP improved when we started to use 1.75 filament instead of 3mm. ( well many of us ), why did we stop there?
[/OT]
@MKSA
Your solution is quite nice, but would it fit on a Smart Effector? Maybe with a radial fan placed on top, could you center the heatsink? Or make it fit under the stepper? The radial fan could then suck in air from around the stepper, for extra cooling.
