Printing different Materials / Multi-Material printing October 12, 2016 10:18AM |
Re: Printing different Materials / Multi-Material printing October 12, 2016 02:43PM |
Re: Printing different Materials / Multi-Material printing October 12, 2016 02:45PM |
Laton
actually trying to print something from different materials... Rubber, Plastic, Metal, etc...
Re: Printing different Materials / Multi-Material printing October 12, 2016 02:49PM |
Re: Printing different Materials / Multi-Material printing October 13, 2016 12:54AM |
Re: Printing different Materials / Multi-Material printing October 13, 2016 02:37AM |
Re: Printing different Materials / Multi-Material printing October 15, 2016 04:31AM |
dc42
...non printing nozzle to a reduced standby temperature, which in combination with retracting some filament when a nozzle goes to standby totally avoids ooze...
Lets skip the metal for a second. I am currently working on a solution in order to combine a variety of materials in one print. Question really is: Would anyone need it? ... or ... What to make of it?Quote
DaGameFace
The problem being if you want two materials in the same print.
Commercial printer sure... but being honest. I have seen a number of small commercial printers <2000€ being on the same or worse quality level as a reprap. So why not have a similar technology in the reparap? ... At this stage the question is whether building a reprap is the way to go, or if a reasonably cheap platform to start with wouldn't be better in terms of focus. (Which than again could be a bought reprap derivative).Quote
ggherbaz
You will have to either have a big pocket for a commercial printer or for your own development.
Sounds awesome! What didQuote
etfrench
I have printed various flexible materials and Nylon together with ABS.
The parkingSounds like a similar solution than the Xioneer solution. But how did you "close" the nozzle?Quote
Srek
two independent x carriages and can switch between materials without heating up or cooling down one hotend or the other. The switch takes maybe a second and the unused printhead stays in a parking position where the nozzle is closed.
Sounds awesome!! What did you make with it?Quote
Srek
Re: Printing different Materials / Multi-Material printing October 15, 2016 06:29AM |
Re: Printing different Materials / Multi-Material printing October 16, 2016 12:57PM |
Re: Printing different Materials / Multi-Material printing October 16, 2016 01:08PM |
Re: Printing different Materials / Multi-Material printing October 16, 2016 05:42PM |
Re: Printing different Materials / Multi-Material printing October 16, 2016 05:46PM |
Laton
So is there really no solution for more than one or two materials?
dc42
Does the Hotend cool down quickly enough?
Did you never have problems with a clogging hotend than with the constant removal of the filament?
Re: Printing different Materials / Multi-Material printing October 16, 2016 06:38PM |
