Slicing models October 22, 2016 10:10AM |
Re: Slicing models October 22, 2016 10:16AM |
kooping
Hi All,
I am new to this site and I have been looking through the various methods available for slicing models. I have noticed that there does not seem to be a fully customisable slicer program that offers full customisation and can do what I want it to do so I thought I would ask if anyone could recommend one.
One option that i want is the option of slicing the outside of a model in lets say 0.05mm layer height and then slice the infill of the model at 0.35mm. That way every 7 outer layers would result in only one infill layer and the printed part would be printed way faster than usual. I am sure this option must exist somewhere. Is there any software out there that can do this for me?
Thanks for the help all.
Mike
Re: Slicing models October 22, 2016 10:36AM |
Re: Slicing models October 22, 2016 11:11AM |
Re: Slicing models October 22, 2016 12:54PM |
ABS reinforced concrete would be better, and you could cure it very quickly in a kitchen steamer.
)the fill holes, depending on your fill material. But it would set quicker than printing the whole thing.|
Re: Slicing models October 22, 2016 12:58PM |
I had wondered about filling parts with resin, but it does assume that the part is both sufficiently 'water-tight' and all of a consistent height, which isn't necessarily the case. Either way, it would be nice to be able to print large parts with traditional infill, but reduce print time by using a big nozzle for the fill.
Re: Slicing models October 22, 2016 01:02PM |
Re: Slicing models October 22, 2016 01:20PM |
Re: Slicing models October 22, 2016 01:34PM |
Re: Slicing models October 22, 2016 04:54PM |
Re: Slicing models October 22, 2016 05:03PM |
kooping
So it seems that the option exists but it's just not really functional. That explains why I never heard of it before.
Thanks all
Mike
Re: Slicing models October 22, 2016 08:47PM |
Re: Slicing models October 22, 2016 08:56PM |
Re: Slicing models October 23, 2016 10:44AM |
Rlewisrlou666
Do not use concrete it will eat any plastic you use.
Re: Slicing models October 23, 2016 11:01AM |
Re: Slicing models October 23, 2016 11:07AM |
Re: Slicing models October 23, 2016 12:19PM |
Rlewisrlou666
Something in the chemical reaction of cement curing just makes plastic fall apart.
[youtu.be]
Also most readily available concrete/cement mixtures contain lye.
Re: Slicing models October 27, 2016 08:05AM |
