E3D PT100
October 23, 2016 12:40AM
I purchased a E3D PT100 and it looks almost identicle to the standard new Thermistor E3D makes
same colour wires, same length.
no writing anywhere to identify it.
how can i test that the PT100 i got is really a PT100 and not just another thermistor?
Makerparts.ca
Your Canadian source for V-Slot Extrusion, CNC and 3D Printing Parts and Accessories.
we are proud to be an official Openbuilds distributor.
Re: E3D PT100
October 23, 2016 03:58AM
Measure its resistance. At room temperature, a PT100 will be a little over 100 ohms, and the E3D thermistor will be somewhat over 100k.
Re: E3D PT100
October 23, 2016 12:34PM
I thought that sensor needed an amplifier board to make compatible...
[wiki.e3d-online.com]
Maybe you got that with the sensor?
EDIT: Apparently not needed on Ultimaker 2+ and Duet Wifi controllers... there is a daughter board for Duet but can use with extended Duet too...
Mind you, a 300C compatible thermistor is a LOT cheaper, and still 1% accurate. Just not easy to obtain and can be very fiddly to fit.
Edited 1 time(s). Last edit at 10/23/2016 12:40PM by DragonFire.
Re: E3D PT100
October 23, 2016 01:29PM
Yes I'm using the duet wifi with pt100 daughterboard
Makerparts.ca
Re: E3D PT100
Makerparts.ca
