Re: Discussion on the Nimble November 02, 2016 07:50AM |
Re: Discussion on the Nimble November 02, 2016 08:40AM |
(emphasis mine)Quote
Lykle
First of all, correct there is no way to adjust the clamping force. None is needed.
Re: Discussion on the Nimble November 02, 2016 09:50AM |
Re: Discussion on the Nimble November 02, 2016 10:13AM |
deckingman
I'm not saying it's right or wrong but Dyze Design don't have the facility to adjust tension their (expensive) extruders. I queried this on another forum and the maker claims that they have the optimum tension for all scenarios and adjustment isn't necessary.
Dyze
Applying too little pressure causes the filament to grind before the motor reaches its full potential. However, applying too much pressure causes the motor struggles against friction, inducing filament deformation,
Re: Discussion on the Nimble November 03, 2016 05:07AM |
Re: Discussion on the Nimble November 03, 2016 05:10AM |
Re: Discussion on the Nimble November 03, 2016 10:44AM |
deckingman
...if the teeth bite deeper into soft filaments so effectively changing the diameter of the hobbed bolt, then wouldn't changing the extrusion multiplier for that filament achieve the same result as adjusting the idler tension?
Re: Discussion on the Nimble November 05, 2016 01:42PM |
Re: Discussion on the Nimble November 05, 2016 02:14PM |
Re: Discussion on the Nimble November 05, 2016 07:21PM |
Re: Discussion on the Nimble November 05, 2016 08:47PM |
Does it have to be optimal, or just good enough to work? Not having to adjust tension is pretty appealing, one less thing to forget, one less source of variability. You're right though, the good old test cube isn't a particularly hard test for extruders.Quote
Origamib
I'm not bought yet, how do we know it is the optimum for each material?
Re: Discussion on the Nimble November 05, 2016 08:51PM |
Re: Discussion on the Nimble November 06, 2016 01:26AM |
Re: Discussion on the Nimble November 06, 2016 06:51AM |
Re: Discussion on the Nimble November 06, 2016 07:12AM |
joking aside|
Re: Discussion on the Nimble November 06, 2016 07:27AM |
Re: Discussion on the Nimble November 06, 2016 07:39AM |
Re: Discussion on the Nimble November 06, 2016 08:30AM |
JamesK
Origamib
Still, given that it was at least working for that test, and I don't think my extruders would without changing the tension, it is interesting to wonder why there is that difference. One thing about these flex drives is that they use a much greater reduction gearing than a typical extruder, so have more torque available. Perhaps they are running at the high end of the tension range, and while the softer filaments may distort, there's enough torque available to overcome the increased friction. Other differences with my setup are that I'm running 3mm filament and using a nema14 stepper with 5:1 gearing, so I'm definitely running very close to the limits of my available torque.
Re: Discussion on the Nimble November 06, 2016 08:38AM |
Re: Discussion on the Nimble November 06, 2016 09:23AM |
Re: Discussion on the Nimble November 06, 2016 09:53AM |
Re: Discussion on the Nimble November 06, 2016 10:10AM |
Re: Discussion on the Nimble November 06, 2016 10:17AM |
Re: Discussion on the Nimble November 06, 2016 11:36AM |
Re: Discussion on the Nimble November 08, 2016 07:53AM |
Re: Discussion on the Nimble November 22, 2016 09:55AM |
Re: Discussion on the Nimble November 22, 2016 10:32AM |
Re: Discussion on the Nimble November 23, 2016 01:41PM |
Re: Discussion on the Nimble December 13, 2016 06:24PM |
Re: Discussion on the Nimble December 14, 2016 03:19AM |
