Vacuum hold-down for 3D build surface. November 11, 2016 10:54AM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 11:27AM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 12:27PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 12:29PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 01:01PM |
You didn't cut 4.5mm deep in a single pass surely? I haven't tried anything as small as 1mm, but with 1/4" mills I usually take 10 to 15 thou on each pass.Quote
leadinglights
The milling on the printer was interesting, not least because I broke best quality German 1mm carbide end mills but a cheap Chinese end mill survived even cutting 5 slots each 4.5mm deep for the vacuum.
Re: Vacuum hold-down for 3D build surface. November 11, 2016 01:16PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 01:20PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 01:48PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 02:45PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 03:29PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 04:11PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 06:37PM |
Re: Vacuum hold-down for 3D build surface. November 11, 2016 06:41PM |
Re: Vacuum hold-down for 3D build surface. November 12, 2016 05:01AM |
Re: Vacuum hold-down for 3D build surface. November 12, 2016 05:31AM |
leadinglights
I think that only a small and simple vacuum pump will be needed - if there is no leakage then a plastic syringe of about 100ml to 250ml would probably work. However, it seems a bit unlikely that a good vacuum could be held for several hours. The ideal pump is possibly a pulsing pump that only pulls when the vacuum falls below a trigger level - in a manner similar to the SU and Bendix pumps used on old cars; but sucking air instead of pumping fuel.
The materials that it would hold down include overhead transparency film and the thin material from laminating pouches. I am sure that most materials will have some problem (softening on the heat bed and being drawn into the grooves or lifting when the print wants to curl etc., but nothing that can't be kicked into shape)
Mike
Re: Vacuum hold-down for 3D build surface. November 12, 2016 12:22PM |
Re: Vacuum hold-down for 3D build surface. November 12, 2016 01:08PM |
the_digital_dentist
I'd probably connect it to the air intake on a small aquarium pump and just let it run continuously.
I don't understand how you're connecting the pump to this- one side gets closed off with the plastic film... what happens on the other side?
Re: Vacuum hold-down for 3D build surface. November 12, 2016 02:42PM |
Re: Vacuum hold-down for 3D build surface. November 12, 2016 02:48PM |
the_digital_dentist
Re: Vacuum hold-down for 3D build surface. November 12, 2016 03:02PM |
Re: Vacuum hold-down for 3D build surface. November 12, 2016 03:57PM |
Re: Vacuum hold-down for 3D build surface. November 13, 2016 01:56AM |
Re: Vacuum hold-down for 3D build surface. November 13, 2016 05:15AM |
Re: Vacuum hold-down for 3D build surface. November 13, 2016 06:54AM |
Re: Vacuum hold-down for 3D build surface. November 13, 2016 07:37AM |
Re: Vacuum hold-down for 3D build surface. November 13, 2016 11:46AM |
Re: Vacuum hold-down for 3D build surface. November 13, 2016 12:56PM |
Re: Vacuum hold-down for 3D build surface. November 15, 2016 02:40PM |
Re: Vacuum hold-down for 3D build surface. November 15, 2016 03:15PM |
leadinglights
I was going to use PTFE shrink sleeving over 0.71mm nichrome but when I tried it out I found that the resistance was too high - 4 Ohms for each half. I have sent for some constantan, also of 0.71mm, which should have a resistance of just under 2 Ohms per half. This is enameled but I will back that up but coating the inside of the grooves with a tough silicone elastomer (Electrolube FSC) and sealing the wire in with the same. silicone.
Mike
Re: Vacuum hold-down for 3D build surface. November 15, 2016 03:39PM |
the_digital_dentist
leadinglights
Mike
PTFE is thermal as well as electrical insulation, as is the silicone elastomer. Your controller is going to be measuring the plate temperature. It will take time for the applied heat to get through the thermal resistances and heat up the bed. During that time the insulated wire is heating to ever higher temperatures. Teflon decomposes at 350C. How do you guarantee that the wire won't get to 350C?
